First/revers idler gear condition, What say the transmission experts? |
draganc |
Jan 8 2019, 12:07 AM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Hi folks!
I’m “freshing” up my transmission that came with my car - I have no idea about it’s condition. Hence, I bought Dr. Evil’s dvd and took the whole shebang a part for inspection. Surprisingly gears 2-5 look very good and it appears that the rings have been replaced and the dog teeth look nice and pointy. The only worn part appears to be the 1/R idler gear, strangely in the middle (yellow circle) and the green areas?!?! Is this normal? I have a spare idler gear with matching 1/R I’m contemplating to swap. Thanks for the groups feedback! (IMG:style_emoticons/default/beerchug.gif) dc PS: the pics were taken before the cleaning. Came out nice and clean. PPS: any suggestions where to buy the thrust and needle bearings? |
Tbrown4x4 |
Jan 8 2019, 05:55 AM
Senior Member Group: Members Posts: 699 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
I'm no Dr. Evil, but the center of the idler isn't a wear surface. They don't waste the machine time making it nice.
The teeth you circled in green are worn, but I've seen worse. If your spare looks better, I'd swap it. |
dr914@autoatlanta.com |
Jan 8 2019, 08:34 AM
914 Guru Group: Members Posts: 7,810 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
if any question you can buy a perfect used one for 25 bucks
Hi folks! I’m “freshing” up my transmission that came with my car - I have no idea about it’s condition. Hence, I bought Dr. Evil’s dvd and took the whole shebang a part for inspection. Surprisingly gears 2-5 look very good and it appears that the rings have been replaced and the dog teeth look nice and pointy. The only worn part appears to be the 1/R idler gear, strangely in the middle (yellow circle) and the green areas?!?! Is this normal? I have a spare idler gear with matching 1/R I’m contemplating to swap. Thanks for the groups feedback! (IMG:style_emoticons/default/beerchug.gif) dc PS: the pics were taken before the cleaning. Came out nice and clean. PPS: any suggestions where to buy the thrust and needle bearings? |
draganc |
Jan 8 2019, 01:16 PM
if any question you can buy a perfect used one for 25 bucks George, Thanks for the tip! I thought the idler and the first/revers gears are a matching set. Is it ok to replace just the idler without the other two or were you referring the $25 for all three gears? Regards, dc PS: do you have them in your web store? How about those new thrust and needle bearings? |
draganc |
Jan 11 2019, 11:33 AM
Any group conclusion if the idler gear is a matching set with the 1st/R gears and OK to be replace indivually, with a other used unit?
Thanks! dc |
Lo-Fi Version | Time is now: 19th April 2024 - 01:57 AM |
