Fix the leaks and new rings., what order for the oil scraper rings |
JimN73 |
Jan 8 2019, 06:28 PM
Senior Member Group: Members Posts: 535 Joined: 6-October 07 From: Gig Harbor Member No.: 8,192 Region Association: Pacific Northwest |
The car has had a minor leak for quite a while, it was small so I didn't do anything with it.
Last fall, new leaks started and turned into quite a mess. Leaks in the cylinder bases, front main and maybe the oil pump. And, of course, leaky pushrod tubes and maybe the oil cooler seals. So the engine out and cleaned up and ready to be resealed. I decided that this would be a good time to change the rings. They're cheap and accessible at this point. Here's the question. There are two small rings in the channel with the oil scraper ring, one above and one below. Is it easier to a thing ring first, followed by the scraper and then the other thin ring? Or the scraper ring and then the two thin rings? Is it necessary to change the thin rings at all? Thanks, |
IronHillRestorations |
Jan 8 2019, 07:41 PM
I. I. R. C. Group: Members Posts: 6,717 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Change all the rings. Proceed with caution and due diligence, lest you err and do it all over again.
Tbrown4x4 |
Jan 8 2019, 11:00 PM
Senior Member Group: Members Posts: 703 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Jim. Call me tomorrow morning. (IMG:style_emoticons/default/smile.gif)
Expander ring first. Butt the ends, no overlap. Then wind in each thin scraper ring. I have ring expanders and compressors. Have you checked ring gaps yet? |
Lo-Fi Version | Time is now: 11th May 2024 - 03:13 PM |
