75 2.0 D-Jet wiring harness, Just fried blue/black wire in the harness |
dennisphelan |
Jan 10 2019, 07:08 PM
Newbie Group: Members Posts: 15 Joined: 10-December 18 From: Dundee Oregon Member No.: 22,713 Region Association: Pacific Northwest |
Hooked up the wire harness that runs from the relay board to the to various connections for the D-ironic fuel injection per Jeff Bowlsby wiring diagram, I installed a new Optima battery and turned on the ignition. Smoke started raising out of the engine compartment. shut it down and see that I melted the Black/Purple wire from the negative 1 terminal on the coil all the way up to the connector on the relay board. it appears to have taken several other wires with it. I think that this wiring harness is toast. I have two problems: (1) need to replace or fix the wiring harness and (2) what went wrong? Any ideas or suggestions on what to do next?
Just checked and found I had forgotten to connect the transmission ground strap. Could that have caused this? |
mgphoto |
Jan 10 2019, 08:41 PM
"If there is a mistake it will find me" Group: Members Posts: 1,330 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
If connected wrong direct connection to ground and without the tranny ground strap turning on the key all the current heads through that path.
Check to see if the contacts are reversed on the ignition coil. |
Olympic 914 |
Jan 10 2019, 08:43 PM
Group: Members Posts: 1,658 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
You hooked up the 12 pin connector 1 pin off.
BTDT. You can cut apart the harness and see how bad it is, you may be able to fix it. OR. Buy a new harness from Jeff (that's what I did) And remember to check that plug 3 times after connecting it to be sure its right. |
Olympic 914 |
Jan 10 2019, 08:56 PM
Also check the green wire going to the dizzy. it may have burnt too....
JeffBowlsby |
Jan 10 2019, 10:07 PM
914 Wiring Harnesses Group: Members Posts: 8,438 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Hi Dennis, no worries, it can all be repaired good as new. The casing needs to be removed/replaced to replace any damaged circuits.
As mentioned, either the 12-pin plug was mis-indexed on the relay board or possibly the two wires to the coil were swapped. A very common issue. |
dennisphelan |
Jan 11 2019, 11:47 AM
Hi Dennis, no worries, it can all be repaired good as new. The casing needs to be removed/replaced to replace any damaged circuits. As mentioned, either the 12-pin plug was mis-indexed on the relay board or possibly the two wires to the coil were swapped. A very common issue. Thanks Jeff. I cut off the casing from the wiring harness last night and the black/purple wire had melted all the way from the board plug to the coil connection. It had heated other wires insulation to the point where the wires were fused. I will be ordering a new one from you today. |
JeffBowlsby |
Jan 11 2019, 11:51 AM
Hi Dennis, no worries, it can all be repaired good as new. The casing needs to be removed/replaced to replace any damaged circuits. As mentioned, either the 12-pin plug was mis-indexed on the relay board or possibly the two wires to the coil were swapped. A very common issue. Thanks Jeff. I cut off the casing from the wiring harness last night and the black/purple wire had melted all the way from the board plug to the coil connection. It had heated other wires insulation to the point where the wires were fused. I will be ordering a new one from you today. I can probably repair the one you have by replacing anything damaged, keeping anything that was not damaged. Saves $. Send it to me and I will have a look |
Lo-Fi Version | Time is now: 28th March 2024 - 11:58 AM |
