75 2.0 D-Jet wiring harness, Just fried blue/black wire in the harness |
dennisphelan |
Jan 10 2019, 07:08 PM
Newbie Group: Members Posts: 15 Joined: 10-December 18 From: Dundee Oregon Member No.: 22,713 Region Association: Pacific Northwest |
Hooked up the wire harness that runs from the relay board to the to various connections for the D-ironic fuel injection per Jeff Bowlsby wiring diagram, I installed a new Optima battery and turned on the ignition. Smoke started raising out of the engine compartment. shut it down and see that I melted the Black/Purple wire from the negative 1 terminal on the coil all the way up to the connector on the relay board. it appears to have taken several other wires with it. I think that this wiring harness is toast. I have two problems: (1) need to replace or fix the wiring harness and (2) what went wrong? Any ideas or suggestions on what to do next?
Just checked and found I had forgotten to connect the transmission ground strap. Could that have caused this? |
mgphoto |
Jan 10 2019, 08:41 PM
"If there is a mistake it will find me" Group: Members Posts: 1,338 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
If connected wrong direct connection to ground and without the tranny ground strap turning on the key all the current heads through that path.
Check to see if the contacts are reversed on the ignition coil. |
Lo-Fi Version | Time is now: 2nd May 2024 - 09:31 PM |
