75 2.0 D-Jet wiring harness, Just fried blue/black wire in the harness |
dennisphelan |
Jan 10 2019, 07:08 PM
Newbie Group: Members Posts: 15 Joined: 10-December 18 From: Dundee Oregon Member No.: 22,713 Region Association: Pacific Northwest |
Hooked up the wire harness that runs from the relay board to the to various connections for the D-ironic fuel injection per Jeff Bowlsby wiring diagram, I installed a new Optima battery and turned on the ignition. Smoke started raising out of the engine compartment. shut it down and see that I melted the Black/Purple wire from the negative 1 terminal on the coil all the way up to the connector on the relay board. it appears to have taken several other wires with it. I think that this wiring harness is toast. I have two problems: (1) need to replace or fix the wiring harness and (2) what went wrong? Any ideas or suggestions on what to do next?
Just checked and found I had forgotten to connect the transmission ground strap. Could that have caused this? |
Olympic 914 |
Jan 10 2019, 08:43 PM
Group: Members Posts: 1,661 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
You hooked up the 12 pin connector 1 pin off.
BTDT. You can cut apart the harness and see how bad it is, you may be able to fix it. OR. Buy a new harness from Jeff (that's what I did) And remember to check that plug 3 times after connecting it to be sure its right. |
Lo-Fi Version | Time is now: 19th April 2024 - 04:55 AM |
