75 2.0 D-Jet wiring harness, Just fried blue/black wire in the harness |
dennisphelan |
Jan 10 2019, 07:08 PM
Newbie Group: Members Posts: 15 Joined: 10-December 18 From: Dundee Oregon Member No.: 22,713 Region Association: Pacific Northwest |
Hooked up the wire harness that runs from the relay board to the to various connections for the D-ironic fuel injection per Jeff Bowlsby wiring diagram, I installed a new Optima battery and turned on the ignition. Smoke started raising out of the engine compartment. shut it down and see that I melted the Black/Purple wire from the negative 1 terminal on the coil all the way up to the connector on the relay board. it appears to have taken several other wires with it. I think that this wiring harness is toast. I have two problems: (1) need to replace or fix the wiring harness and (2) what went wrong? Any ideas or suggestions on what to do next?
Just checked and found I had forgotten to connect the transmission ground strap. Could that have caused this? |
JeffBowlsby |
Jan 10 2019, 10:07 PM
914 Wiring Harnesses Group: Members Posts: 8,470 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Hi Dennis, no worries, it can all be repaired good as new. The casing needs to be removed/replaced to replace any damaged circuits.
As mentioned, either the 12-pin plug was mis-indexed on the relay board or possibly the two wires to the coil were swapped. A very common issue. |
dennisphelan |
Jan 11 2019, 11:47 AM
Hi Dennis, no worries, it can all be repaired good as new. The casing needs to be removed/replaced to replace any damaged circuits. As mentioned, either the 12-pin plug was mis-indexed on the relay board or possibly the two wires to the coil were swapped. A very common issue. Thanks Jeff. I cut off the casing from the wiring harness last night and the black/purple wire had melted all the way from the board plug to the coil connection. It had heated other wires insulation to the point where the wires were fused. I will be ordering a new one from you today. |
Lo-Fi Version | Time is now: 18th April 2024 - 08:00 AM |
