A Arm Bushings, A Arm Bushings |
Ken Mikos |
Jan 10 2019, 07:58 PM
Newbie Group: Members Posts: 28 Joined: 20-February 14 From: Pgh Member No.: 17,024 Region Association: None |
Ok all, finished replacing the Motor and Tranny Mounts and it made a huge overall difference. Thanks for all the suggestions.
With that project completed, I have decided to replace the A Arm Bushings. Any suggestions on which bushings or rebuilt A Arms i should use would be much appreciated. Thanks again... |
mb911 |
Jan 10 2019, 08:20 PM
914 Guru Group: Members Posts: 6,748 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Ok all, finished replacing the Motor and Tranny Mounts and it made a huge overall difference. Thanks for all the suggestions. With that project completed, I have decided to replace the A Arm Bushings. Any suggestions on which bushings or rebuilt A Arms i should use would be much appreciated. Thanks again... 914rubber.com |
914Sixer |
Jan 10 2019, 10:06 PM
914 Guru Group: Members Posts: 8,840 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Get it with the installation tool.
SO.O.C914er |
Jan 10 2019, 10:19 PM
Senior Member Group: Members Posts: 1,235 Joined: 18-July 16 From: Mission Viejo Ca Member No.: 20,199 Region Association: Southern California |
When installing the bushings should you use some kind of grease? If so what is best.
bbrock |
Jan 10 2019, 10:23 PM
iankarr |
Jan 10 2019, 10:47 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,469 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Thanks, Brent for sharing the video. That one took at least a few hours off my life (IMG:style_emoticons/default/wink.gif).
@ken mikos If you're getting new A-arms, get the ones with the drop link brackets already installed. If you have a front sway bar, you've already got em. If you don't, someday you may want to install one and you'll be glad you don't have to mess with adding the brackets. |
Larmo63 |
Jan 11 2019, 12:12 AM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
IronHillRestorations |
Jan 11 2019, 08:46 AM
I. I. R. C. Group: Members Posts: 6,707 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I'm working on this now, but I'm using stock bushings. They are pretty cheap, about $100 for a set of four. They are (of course) the correct durometer rubber, the difficulty is installation, which I'm working on a solution for that, but I don't know if it can be done without a press.
UROpartsman |
Jan 11 2019, 10:50 AM
Member Group: Members Posts: 290 Joined: 22-October 15 From: Simi Valley, CA Member No.: 19,288 Region Association: None |
If anyone is interested, in late 2017 we released a "Heavy Duty" performance version of our Front Control Arm Bushings 901 341 421 02KHD, which are about 30% more firm than the OEM rubber. These do require considerable heat (boiling water) and some kind of press arrangement to install, and are definitely not a slip-fit.
Attached thumbnail(s) |
Frank S |
Jan 12 2019, 10:20 AM
Member Group: Members Posts: 135 Joined: 15-April 15 From: Wiesbaden, Germany Member No.: 18,632 Region Association: Germany |
I'm working on this now, but I'm using stock bushings. They are pretty cheap, about $100 for a set of four. They are (of course) the correct durometer rubber, the difficulty is installation, which I'm working on a solution for that, but I don't know if it can be done without a press. Hi Perry, do you have a source for the Stock bushings? Thanks, Frank |
Matty900 |
Jan 12 2019, 06:37 PM
Senior Member Group: Members Posts: 1,269 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
I'm working on this now, but I'm using stock bushings. They are pretty cheap, about $100 for a set of four. They are (of course) the correct durometer rubber, the difficulty is installation, which I'm working on a solution for that, but I don't know if it can be done without a press. Much easier with a tool, hot water, a lot of soft soap and a lot of patience. We have the tool and the bushings (with the correct durometer rubber) for about $65. https://900designs-container.zoeysite.com/c...-install-tool-1 |
Lo-Fi Version | Time is now: 28th March 2024 - 05:33 AM |
