A Arm Bushings, A Arm Bushings |
Ken Mikos |
Jan 10 2019, 07:58 PM
Newbie Group: Members Posts: 28 Joined: 20-February 14 From: Pgh Member No.: 17,024 Region Association: None |
Ok all, finished replacing the Motor and Tranny Mounts and it made a huge overall difference. Thanks for all the suggestions.
With that project completed, I have decided to replace the A Arm Bushings. Any suggestions on which bushings or rebuilt A Arms i should use would be much appreciated. Thanks again... |
IronHillRestorations |
Jan 11 2019, 08:46 AM
I. I. R. C. Group: Members Posts: 6,707 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I'm working on this now, but I'm using stock bushings. They are pretty cheap, about $100 for a set of four. They are (of course) the correct durometer rubber, the difficulty is installation, which I'm working on a solution for that, but I don't know if it can be done without a press.
Matty900 |
Jan 12 2019, 06:37 PM
Senior Member Group: Members Posts: 1,269 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
I'm working on this now, but I'm using stock bushings. They are pretty cheap, about $100 for a set of four. They are (of course) the correct durometer rubber, the difficulty is installation, which I'm working on a solution for that, but I don't know if it can be done without a press. Much easier with a tool, hot water, a lot of soft soap and a lot of patience. We have the tool and the bushings (with the correct durometer rubber) for about $65. https://900designs-container.zoeysite.com/c...-install-tool-1 |
Lo-Fi Version | Time is now: 28th March 2024 - 04:47 PM |
