Exhaust question for 2.0l case with 1.8 heads |
Tdskip |
Jan 10 2019, 09:05 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Newbie Type 4 question here - are the exhausts interchange post exhaust manifolds that come from the heads?
Assuming that the total flow would be based on the displacement? Thanks! |
Dave_Darling |
Jan 11 2019, 01:03 AM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The exhausts are interchangeable as a unit. The heat exchangers, muffler, and muffler hanger must match, but they don't care which version of the 914 engine they go on.
There were three factory versions of the exhaust: The 1.7 version (which was also used on the 74 1.8s), the 2.0 version (73-74 2-liters), and the late version (used on all 75-76 914s, both 1.8 and 2 liter). The late exhaust is the only one that has a separate "header" piece that bolts to the exhaust ports, both earlier versions have the header and heat exchanger as a single part. Note that the heater stuff that bolts up to the exchangers will swap between the 1.7 and 2.0 versions of the exhaust, most the late style heater bits only bolt up to the late style exhaust. Here is a pic of the two early style heat exchangers, courtesy of Jeff Bowlsby's tech pages: (IMG:http://www.914world.com/bbs2/uploads_offsite/bowlsby.net-121-1547190238.1.jpg) Here's a pic of the late style ones: (IMG:http://www.914world.com/bbs2/uploads/post-5678-1233594136.jpg) --DD |
Lo-Fi Version | Time is now: 6th May 2024 - 08:11 AM |
