Exhaust question for 2.0l case with 1.8 heads |
Tdskip |
Jan 10 2019, 09:05 PM
Advanced Member Group: Members Posts: 3,678 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Newbie Type 4 question here - are the exhausts interchange post exhaust manifolds that come from the heads?
Assuming that the total flow would be based on the displacement? Thanks! |
brant |
Jan 11 2019, 02:31 PM
914 Wizard Group: Members Posts: 11,603 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
original poster said "2.0 case"
that doesn't guarantee that it is a 2.0 engine... he may not realize that all cases are the same and he did not clarify if its a 2.0 crank/rods |
Tdskip |
Jan 11 2019, 02:50 PM
original poster said "2.0 case" that doesn't guarantee that it is a 2.0 engine... he may not realize that all cases are the same and he did not clarify if its a 2.0 crank/rods Hi - yes, was trying to be specific. From what I was told it’s a 2.0 L bottom end with 1.8 heads that were tailored to fit. She feels quite lively, has decent torque for whatever that’s worth. Thanks for the response by the way. |
mepstein |
Jan 11 2019, 03:01 PM
914-6 GT in waiting Group: Members Posts: 19,220 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
original poster said "2.0 case" that doesn't guarantee that it is a 2.0 engine... he may not realize that all cases are the same and he did not clarify if its a 2.0 crank/rods Hi - yes, was trying to be specific. From what I was told it’s a 2.0 L bottom end with 1.8 heads that were tailored to fit. She feels quite lively, has decent torque for whatever that’s worth. Thanks for the response by the way. Some guys prefer to use 1.8 heads for their performance engines. I have no idea if this was the case with yours. |
brant |
Jan 11 2019, 03:10 PM
original poster said "2.0 case" that doesn't guarantee that it is a 2.0 engine... he may not realize that all cases are the same and he did not clarify if its a 2.0 crank/rods Hi - yes, was trying to be specific. From what I was told it’s a 2.0 L bottom end with 1.8 heads that were tailored to fit. She feels quite lively, has decent torque for whatever that’s worth. Thanks for the response by the way. Some guys prefer to use 1.8 heads for their performance engines. I have no idea if this was the case with yours. Also pull the case numbers... it could be a big bore kit on a 1.8 which makes it effectively a 2.0 and often people will call a big bore motor a "2 liter" This is the most likely reason for someone to have 1.8 heads on a "2 liter" |
Tdskip |
Jan 11 2019, 03:13 PM
original poster said "2.0 case" that doesn't guarantee that it is a 2.0 engine... he may not realize that all cases are the same and he did not clarify if its a 2.0 crank/rods Hi - yes, was trying to be specific. From what I was told it’s a 2.0 L bottom end with 1.8 heads that were tailored to fit. She feels quite lively, has decent torque for whatever that’s worth. Thanks for the response by the way. Some guys prefer to use 1.8 heads for their performance engines. I have no idea if this was the case with yours. Also pull the case numbers... it could be a big bore kit on a 1.8 which makes it effectively a 2.0 and often people will call a big bore motor a "2 liter" This is the most likely reason for someone to have 1.8 heads on a "2 liter" Thanks guys - great input, thanks. It is a 2.0L case, don't have the number at my finger tips, but I checked it before I bought it and it's is (or was) a proper 2.0L case and not from a Bus. |
Lo-Fi Version | Time is now: 19th April 2024 - 07:42 AM |
