What is this? |
What is this? |
Targa70 |
Jan 11 2019, 09:24 AM
Member Group: Members Posts: 80 Joined: 22-March 13 From: Virginia Member No.: 15,683 Region Association: None |
So I was going thru a box that came with my 914/6 when I bought it 15 years ago. I came across this long thin "T"ish shaped part and am not sure what it is. The seller sent the box with the car which included, in addition to the part in question, oil lines for a 914/6, door latch assemblies, and a couple of other miscellaneous body parts. It may be off a 911 also.... It is hard to tell from the pics, but it is a golden cad color with no rusting. Maybe something off an early 911's MFI?
Attached thumbnail(s) |
dr914@autoatlanta.com |
Jan 11 2019, 11:22 AM
914 Guru Group: Members Posts: 7,772 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
feeds the cold start system injecting gas down the throat of the intake stacks, great fire hazard
So I was going thru a box that came with my 914/6 when I bought it 15 years ago. I came across this long thin "T"ish shaped part and am not sure what it is. The seller sent the box with the car which included, in addition to the part in question, oil lines for a 914/6, door latch assemblies, and a couple of other miscellaneous body parts. It may be off a 911 also.... It is hard to tell from the pics, but it is a golden cad color with no rusting. Maybe something off an early 911's MFI? |
UROpartsman |
Jan 11 2019, 11:29 AM
Member Group: Members Posts: 290 Joined: 22-October 15 From: Simi Valley, CA Member No.: 19,288 Region Association: None |
These tubes are likely part of the original cold start fuel system originally installed on very early 6s, which were recalled and removed due to fires. Basically the circuit dumped raw fuel into the air cleaner tops via these pipes and a solenoid.
Edit: George was faster on the draw, lol. |
Targa70 |
Jan 11 2019, 11:34 AM
yep, that makes sense. Also in the box was a fuel start solenoid. thank you.
Lo-Fi Version | Time is now: 28th March 2024 - 11:13 PM |
