AAR year result on 1.7 FI | cold start suction means OK? |
Tdskip |
Jan 11 2019, 01:25 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
First of all thank you for all your help and patience as I work through these issues on the ‘73 1.7 FI car.
I’m having idle and loss of power issues that I’m trying to get sorted out. Brand new MPS from Jeff 40 PSI fuel pressure at the pump outlet Just did a cold start test on the AAR by immediately pulling the hose that goes to the rubber install and I had suction there. That suggests that my AAR is OK and I should keep moving on to other components, correct? |
914_teener |
Jan 11 2019, 03:42 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Tom,
You can remove the AAR and bench test it by looking at it visually. 12v and just ground to the body of the AAR and the valve should slowly close. Easy peasy. |
Lo-Fi Version | Time is now: 5th May 2024 - 11:43 AM |
