AAR year result on 1.7 FI | cold start suction means OK? |
Tdskip |
Jan 11 2019, 01:25 PM
First of all thank you for all your help and patience as I work through these issues on the ‘73 1.7 FI car.
I’m having idle and loss of power issues that I’m trying to get sorted out. Brand new MPS from Jeff 40 PSI fuel pressure at the pump outlet Just did a cold start test on the AAR by immediately pulling the hose that goes to the rubber install and I had suction there. That suggests that my AAR is OK and I should keep moving on to other components, correct? |
JawjaPorsche |
Jan 11 2019, 03:51 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
Idle issues usually is a vacuum leak somewhere.
I had a hard time sorting mine out. I noticed your hoses look new so we can cancel that off the list. Things to replace: Manifold gaskets. Injector seals Air intake gasket Oil fill gasket Good luck! |
Lo-Fi Version | Time is now: 5th May 2024 - 12:06 PM |
