EMPI EPC 34 carbs, Re jetting for a 1911 |
jsaum |
Jan 11 2019, 02:58 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
I have a 1.8 with the dual EMPI EPC 34's on it, they work great. I'm about to do a top end rebuild on the 1.8 and have the option to bump it up to a 1911. These little carbs are rated up to the 1.8, I'm thinking if I go to the 1911 I will need a little more out of the carbs. Has anyone gone to bigger jets successfully on these carbs? If yes how much bigger would I need to go? They come standard with 1.75 needle and seat, 150 main jet, 55 Idle jet, 175 air jet and F-6 Emulsion tube.
Thanks, Jsaum |
Mark Henry |
Jan 11 2019, 10:25 PM
For carbs I'd only use dual IDF's or dells.
I'd put together a Ljet system before using a 2x single barrel carbs or a progressive. |
jsaum |
Jan 12 2019, 04:33 PM
For carbs I'd only use dual IDF's or dells. I'd put together a Ljet system before using a 2x single barrel carbs or a progressive. I have a set of 36 dells just need to go through them. I also have an L jet in the works too. As a short term stop gap measure I might try going up one size on the main jets on the 34s. I’m trying to stop myself from having a half dozen projects going at once. |
Lo-Fi Version | Time is now: 4th May 2024 - 02:41 PM |
