914 Rubber Headlight Restoration Kit Group Buy, Working on the final parts now. |
Matty900 |
Jan 11 2019, 08:22 PM
Senior Member Group: Members Posts: 1,269 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
We have made all of the parts needed to restore your pop up headlights. We are just finalizing the headlight adjuster screws (that are always stripped out.)
We have made: -New white and black headlight surrounds -New Pivot Shaft bushings -New Push Rods (for the Late Cars) -New Splash Guards (for the Early Cars) -New Brush's -New Adjuster Screws (These are still in process so they will not be in the kits. You will be able to order them later if you need them) -New Adjuster Blocks -Color matched paint for restoring the housing -Option for new LED Headlights -Option for New Headlight Globes -New "Eyebrow" Grommets -New Cad Plated 2 hole and 3 hole backing plates. -New improved Headlight Wiring Harness grommets -New Wiring Harness Anti Chafing edge protectors (for Late cars) This should be a great project and satisfying to complete. You can buy most of these parts now on the new website but we will have a group buy for the Restoration Kit for 914 World Members first. Who wants one? (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) |
bbrock |
Jan 14 2019, 03:47 PM
I'll be in for a few of the individual parts.
Matty900 |
Feb 9 2019, 09:41 PM
I'll be in for a few of the individual parts. We tried to set the kits up at a basic level for the things that you will need and then made other parts options or suggestions to try and make it as much or as little as you want for the kits. Some of the parts are only available in the kits at this time but will become available later after we have enough in stock and have filled the kit orders. I sent you a PM with the discount code (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 24th April 2024 - 12:49 AM |
