914 Rubber Headlight Restoration Kit Group Buy, Working on the final parts now. |
Matty900 |
Jan 11 2019, 08:22 PM
Senior Member Group: Members Posts: 1,269 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
We have made all of the parts needed to restore your pop up headlights. We are just finalizing the headlight adjuster screws (that are always stripped out.)
We have made: -New white and black headlight surrounds -New Pivot Shaft bushings -New Push Rods (for the Late Cars) -New Splash Guards (for the Early Cars) -New Brush's -New Adjuster Screws (These are still in process so they will not be in the kits. You will be able to order them later if you need them) -New Adjuster Blocks -Color matched paint for restoring the housing -Option for new LED Headlights -Option for New Headlight Globes -New "Eyebrow" Grommets -New Cad Plated 2 hole and 3 hole backing plates. -New improved Headlight Wiring Harness grommets -New Wiring Harness Anti Chafing edge protectors (for Late cars) This should be a great project and satisfying to complete. You can buy most of these parts now on the new website but we will have a group buy for the Restoration Kit for 914 World Members first. Who wants one? (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) |
SixerJ |
Jan 30 2019, 05:34 AM
Member Group: Members Posts: 448 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
Interested (early white surround) but just to add a variation I’m going to install GT pop up so probably don’t need the motor links. All will become clear in due course I guess
Matty900 |
Feb 9 2019, 11:15 PM
Interested (early white surround) but just to add a variation I’m going to install GT pop up so probably don’t need the motor links. All will become clear in due course I guess @sixerJ Interesting, if you remove the motor and the push rod, will not need the brushes and the splash guard, but you will be left with a hole into your trunk that you will likely want to seal up. What are your plans for that? I sent you a PM if you want the discount code for the kit |
Lo-Fi Version | Time is now: 19th April 2024 - 08:13 AM |
