Rust cover up?, Car looks good, but how can I tell if rust is just covered |
Jon199 |
Jan 12 2019, 07:25 AM
Newbie Group: Members Posts: 4 Joined: 8-January 19 From: Maine Member No.: 22,787 Region Association: North East States |
I am considering purchasing this project 914. I am concerned that rust may have been covered up by a rhino lining or similar spray application at the hell hole. Does anyone have any knowledge of the car or any advice as to what exactly what I should be looking for when I go inspect the car in person?
Thanks, Jon [attachmentid=682 144] Attached image(s) |
Jon199 |
Jan 13 2019, 04:05 PM
Thank you everyone for your opinions and advice. My first Porsche was a 993. I loved the car, but did not like how the ass end would get light if you let off the gas in a corner. I would like to get a mid engine Porsche this time around. I like the idea of a light 914, but I want to have enough power to give that pushed back into the seat feeling. Also, I want something I can drive to the track for drivers education a few times a year. So I should probably be looking for a cayman. Any thoughts?
Thanks, Jon |
Superhawk996 |
Jan 14 2019, 06:30 PM
914 Guru Group: Members Posts: 5,852 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Thank you everyone for your opinions and advice. My first Porsche was a 993. I loved the car, but did not like how the ass end would get light if you let off the gas in a corner. I would like to get a mid engine Porsche this time around. I like the idea of a light 914, but I want to have enough power to give that pushed back into the seat feeling. Also, I want something I can drive to the track for drivers education a few times a year. So I should probably be looking for a cayman. Any thoughts? Thanks, Jon Jon, there is a fine line between a car that is neutral in a corner and one that gets light tending toward classic oversteer (i.e. 911's). Frankly that line is based on personal opinion and driving style. The secret is don't lift in the corner. If you have your speed set at corner entry, you really want to be easing back into the throttle during the corner rather than lifting which is panic reaction to having gone in too fast. This transfers weight to the rear axle and helps stabilize that rear end. However, you are on the right track. Do as much driver education and track time as you can afford and find time for. You won't regret it. A Cayman is a fine car but being that it is a Porsche you'll find that it too will be neutral to oversteering on an abrupt lift throttle. You can't go wrong with a Cayman but don't expect it to be forgiving of an abrupt lift during a corner either. If you're not already aware, the main issue with 914 handling (and a mid-engine Cayman) is that once you start to lose it, the car can rotate pretty fast due to low polar moment of inertia that is why we love mid-engine handling in the first place. Good luck in your quest. |
Lo-Fi Version | Time is now: 22nd May 2024 - 08:23 PM |
