FS: 5-Lug Rear Trailing Arms w/ Calipers |
andrew15 |
Jan 14 2019, 06:50 PM
Newbie Group: Members Posts: 40 Joined: 10-April 10 From: Thunder Bay, ON Member No.: 11,594 Region Association: None |
I've got a pair of 5-lug converted trailing arms for sale.
- 5-Lug hubs are 914 hubs, plated, drilled and pressed studs - Arms were assembled with new bearings and have about 20 hrs of track time on them - Inner flanges are standard 914 - Rebuilt calipers were fit at the time, but were raw cast finish and have surface rust now - Rotors are vented and cross drilled - have a bit of surface rust that should clean up well - paint on them is the original from when they were purchased new These have about 20 hours of track time on them - surface rusty calipers and rotors because I haven't been at the track in a couple years now (IMG:style_emoticons/default/sad.gif) I noticed today that the rear arms look like they are from different years as the brake line points are in different locations - not sure if that matters Looking for $500 + 75 to help with shipping Thanks Andrew M Attached thumbnail(s) |
bdstone914 |
Jan 20 2019, 05:29 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Are they M calipers on the rear? What front calipers were you using? One would need bigger front calipers to get the brake bias correct.
@andrew15 |
Lo-Fi Version | Time is now: 16th May 2024 - 11:26 PM |
