Time To Do The Engine, Going with a SCAT 2366cc |
7TPorsh |
Jan 15 2019, 04:58 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
Well, car is running like crap and compression is 98-110. Buddy mechanic says there isn't enough there to work with. So need to explore options. Was looking for a 6 awhile ago but that's just too expensive.
I have a 1971 1.7 block (car is 1970), may have bigger cylinders in it but don't know. What are the options if on a slightly restricted budget? I want big and more power but I know there's a tipping point on that. I see new engines advertised here and there. SCAT 2056. Contemplating, do I buy a new engine like this? (any others out there?) or rebuild what I have using a SCAT engine kit or piecing it together using various kits. How big can I easily (budget) go? Currently don't know what I have so assumming a new cam, new crank, etc. I plan on using the existing dual Weber 40IDFs and the MSDS headers/muffler. Here's a pic so there's something visual here. (IMG:style_emoticons/default/beerchug.gif) |
7TPorsh |
Jan 15 2019, 05:35 PM
I have a fairly reasonable mechanic and access to reasonable machining. So a straight remove replace would be ideal. If I can rebuild and go big enough and powerful enough to be better than complete 2056 I think I might opt that way. How big can I safely go with a 1.7 block and heads....is it worth it or do I really need to get a 2.0 blck.
I really like the idea of keeping it aircooled; mainly for the classic character of the car and it's simplicity of operation and maintenance. I can say I have an "air cooled Porsche". I;ve seen some pretty damn fast Bugs. Otherwise I'd drop a 350 in it and be done with it. |
mepstein |
Jan 15 2019, 05:45 PM
914-6 GT in waiting Group: Members Posts: 19,245 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I have a fairly reasonable mechanic and access to reasonable machining. So a straight remove replace would be ideal. If I can rebuild and go big enough and powerful enough to be better than complete 2056 I think I might opt that way. How big can I safely go with a 1.7 block and heads....is it worth it or do I really need to get a 2.0 blck. I really like the idea of keeping it aircooled; mainly for the classic character of the car and it's simplicity of operation and maintenance. I can say I have an "air cooled Porsche". I;ve seen some pretty damn fast Bugs. Otherwise I'd drop a 350 in it and be done with it. Remember, All the blocks are (almost) exactly the same and can be made into any engine size. Jake Raby has often said the early 1.7's were the best blocks for monster engines since the metal mix was slightly better. |
Lo-Fi Version | Time is now: 29th April 2024 - 04:48 PM |
