Time To Do The Engine, Going with a SCAT 2366cc |
7TPorsh |
Jan 15 2019, 04:58 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
Well, car is running like crap and compression is 98-110. Buddy mechanic says there isn't enough there to work with. So need to explore options. Was looking for a 6 awhile ago but that's just too expensive.
I have a 1971 1.7 block (car is 1970), may have bigger cylinders in it but don't know. What are the options if on a slightly restricted budget? I want big and more power but I know there's a tipping point on that. I see new engines advertised here and there. SCAT 2056. Contemplating, do I buy a new engine like this? (any others out there?) or rebuild what I have using a SCAT engine kit or piecing it together using various kits. How big can I easily (budget) go? Currently don't know what I have so assumming a new cam, new crank, etc. I plan on using the existing dual Weber 40IDFs and the MSDS headers/muffler. Here's a pic so there's something visual here. (IMG:style_emoticons/default/beerchug.gif) |
7TPorsh |
Jan 15 2019, 05:36 PM
Open to FI if it fits budget, etc.
Mark Henry |
Jan 15 2019, 07:05 PM
Open to FI if it fits budget, etc. Stock FI will only work with a stock cam or WEB #73 (may be other aftermarket cams) Aftermarket FI even MS and scrounging DIY, etc the intake, will be well over $1000, more likely $2K. Soup to nuts systems with CB ITB's likely will be more in the $3-4K range. They run most cams but may have issue (MAP vac signal) with real lumpy cams. Carbs are still the cheapest option with performance cams and can be made to run well. Carbs do get poorer gas mileage, if it's a daily driver i'd pony up for the FI, but a weekend toy I'd likely just live with the carbs. |
Lo-Fi Version | Time is now: 29th April 2024 - 02:18 PM |
