Time To Do The Engine, Going with a SCAT 2366cc |
7TPorsh |
Jan 15 2019, 04:58 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
Well, car is running like crap and compression is 98-110. Buddy mechanic says there isn't enough there to work with. So need to explore options. Was looking for a 6 awhile ago but that's just too expensive.
I have a 1971 1.7 block (car is 1970), may have bigger cylinders in it but don't know. What are the options if on a slightly restricted budget? I want big and more power but I know there's a tipping point on that. I see new engines advertised here and there. SCAT 2056. Contemplating, do I buy a new engine like this? (any others out there?) or rebuild what I have using a SCAT engine kit or piecing it together using various kits. How big can I easily (budget) go? Currently don't know what I have so assumming a new cam, new crank, etc. I plan on using the existing dual Weber 40IDFs and the MSDS headers/muffler. Here's a pic so there's something visual here. (IMG:style_emoticons/default/beerchug.gif) |
914forme |
Jan 15 2019, 09:26 PM
Tangerine header and muffler will push to half or more of your rebuild budget.
I have run 1911s and they can be a blast, move you along nicely and are not that bad to build. I would go 2270 if you can source parts well. But then have you ever thought about ...... Subaru (IMG:style_emoticons/default/confused24.gif) 2.5L none turbo, with an MT5 is the best step out there, and you can find the donor with everything you might need. except the mount, not hard, and the cable shifter pieces, which can be sourced from 818 part suppliers. Donor #1 Donor #2 Both public can buy, both are pure sale, both run and drive. Just go in knowing your budget you want to spend. Bid, and you might get one. Subaru sixes are not much more than the 2.5L -4s. Every now and again complete swaps show up on here from people installing new combinations for more HP. |
Lo-Fi Version | Time is now: 29th April 2024 - 11:58 AM |
