Time To Do The Engine, Going with a SCAT 2366cc |
7TPorsh |
Jan 15 2019, 04:58 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
Well, car is running like crap and compression is 98-110. Buddy mechanic says there isn't enough there to work with. So need to explore options. Was looking for a 6 awhile ago but that's just too expensive.
I have a 1971 1.7 block (car is 1970), may have bigger cylinders in it but don't know. What are the options if on a slightly restricted budget? I want big and more power but I know there's a tipping point on that. I see new engines advertised here and there. SCAT 2056. Contemplating, do I buy a new engine like this? (any others out there?) or rebuild what I have using a SCAT engine kit or piecing it together using various kits. How big can I easily (budget) go? Currently don't know what I have so assumming a new cam, new crank, etc. I plan on using the existing dual Weber 40IDFs and the MSDS headers/muffler. Here's a pic so there's something visual here. (IMG:style_emoticons/default/beerchug.gif) |
914_teener |
Jan 15 2019, 09:40 PM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Put new pistons 96's and rebuild the heads. 2k.
1911. Keep everything else the way it is. Get a six....986 or 987 and drive it like you stole it.. Best of both worlds. |
7TPorsh |
Jan 16 2019, 11:15 AM
Put new pistons 96's and rebuild the heads. 2k. 1911. Keep everything else the way it is. Get a six....986 or 987 and drive it like you stole it.. Best of both worlds. So 96mm cylinders would equate to 1911? I assume rebuilding the heads dosen't add displacement. WHat is the jump to a 2056? bigger cylinders? Am I buying new cylinders and pistons vs. boring out what I have? Are cam and crank the same? I have carbs and intakes. Unless FI is under $500 I'll stay with the carbs. Would sell the carbs to fund the FI. Not familiar with FI too much. I also have a performance 4 to 1 header from Marty and a Spintech racing muffler so exhaust and intake spoken for. I have an '84 944 for civilized fun. |
Lo-Fi Version | Time is now: 29th April 2024 - 05:37 PM |
