Time To Do The Engine, Going with a SCAT 2366cc |
7TPorsh |
Jan 15 2019, 04:58 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
Well, car is running like crap and compression is 98-110. Buddy mechanic says there isn't enough there to work with. So need to explore options. Was looking for a 6 awhile ago but that's just too expensive.
I have a 1971 1.7 block (car is 1970), may have bigger cylinders in it but don't know. What are the options if on a slightly restricted budget? I want big and more power but I know there's a tipping point on that. I see new engines advertised here and there. SCAT 2056. Contemplating, do I buy a new engine like this? (any others out there?) or rebuild what I have using a SCAT engine kit or piecing it together using various kits. How big can I easily (budget) go? Currently don't know what I have so assumming a new cam, new crank, etc. I plan on using the existing dual Weber 40IDFs and the MSDS headers/muffler. Here's a pic so there's something visual here. (IMG:style_emoticons/default/beerchug.gif) |
914_teener |
Jan 15 2019, 09:40 PM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Put new pistons 96's and rebuild the heads. 2k.
1911. Keep everything else the way it is. Get a six....986 or 987 and drive it like you stole it.. Best of both worlds. |
7TPorsh |
Jan 16 2019, 11:15 AM
Put new pistons 96's and rebuild the heads. 2k. 1911. Keep everything else the way it is. Get a six....986 or 987 and drive it like you stole it.. Best of both worlds. So 96mm cylinders would equate to 1911? I assume rebuilding the heads dosen't add displacement. WHat is the jump to a 2056? bigger cylinders? Am I buying new cylinders and pistons vs. boring out what I have? Are cam and crank the same? I have carbs and intakes. Unless FI is under $500 I'll stay with the carbs. Would sell the carbs to fund the FI. Not familiar with FI too much. I also have a performance 4 to 1 header from Marty and a Spintech racing muffler so exhaust and intake spoken for. I have an '84 944 for civilized fun. |
BeatNavy |
Jan 16 2019, 12:34 PM
So 96mm cylinders would equate to 1911? I assume rebuilding the heads dosen't add displacement. WHat is the jump to a 2056? bigger cylinders? Am I buying new cylinders and pistons vs. boring out what I have? Are cam and crank the same? I have carbs and intakes. Unless FI is under $500 I'll stay with the carbs. Would sell the carbs to fund the FI. Not familiar with FI too much. 96mm P&C plus the 1.7L crank get you to 1911. If you get a 2.0 Crank (71 mm), you get the 2056. So no, the crank is not the same vs. 1.7. No machining required to drop 96 mm cylinders in (although it might be desirable if the case is out of alignment -- but no boring required). I mentioned $500 as the possible FI cost - what I should have said is you may be able to get a serviceable D-Jet setup for that. As Mark Henry said, anything modern is going to be a good bit more. Lots of good ideas from people. It's up to you based on your budget, desire for power, desire to learn, and desire to get back on the road quickly. I agree with those that say the quickest, cheapest, and easiest route is to buy something that someone already built (either from a place like FAT or from someone who is now looking to go in a different direction from something they previously built/bought). The only real downside to that approach is you don't learn as much and you didn't build it yourself exactly the way you wanted. To some people that matters - others, not so much. |
Lo-Fi Version | Time is now: 29th April 2024 - 02:22 PM |
