Time To Do The Engine, Going with a SCAT 2366cc |
7TPorsh |
Jan 15 2019, 04:58 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
Well, car is running like crap and compression is 98-110. Buddy mechanic says there isn't enough there to work with. So need to explore options. Was looking for a 6 awhile ago but that's just too expensive.
I have a 1971 1.7 block (car is 1970), may have bigger cylinders in it but don't know. What are the options if on a slightly restricted budget? I want big and more power but I know there's a tipping point on that. I see new engines advertised here and there. SCAT 2056. Contemplating, do I buy a new engine like this? (any others out there?) or rebuild what I have using a SCAT engine kit or piecing it together using various kits. How big can I easily (budget) go? Currently don't know what I have so assumming a new cam, new crank, etc. I plan on using the existing dual Weber 40IDFs and the MSDS headers/muffler. Here's a pic so there's something visual here. (IMG:style_emoticons/default/beerchug.gif) |
7TPorsh |
Jan 18 2019, 12:04 PM
Thanks Guys, this is really great info.
So it looks like I will be deciding between a 1911 and a 2056. To verify, it sounds like at a base, both will require 96mm cans. And if I go to 2056 will I only need a 71mm crank and related connecting rods? So I'm getting 145cc just by changing crank and rods? I see 96mm PCs from cast iron to alluminum, etc. Will I feel a difference with aluminum all other things remaining equal? I'd like to keep the car more on the bullet-proof side vs. touchy. Who has the best deal around? in either case, will I need to open up the heads to 96mm? Is it called bore? Someone mentioned enlarging valves. Would this be only in the 2056 scenario or could do to a 1911. I anticipate that kind of headwork would be expensive. I am seeing a trend for basic headwork at around $700-800. |
Dave_Darling |
Jan 18 2019, 06:39 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
So it looks like I will be deciding between a 1911 and a 2056. To verify, it sounds like at a base, both will require 96mm cans. And if I go to 2056 will I only need a 71mm crank and related connecting rods? So I'm getting 145cc just by changing crank and rods? Pistons, too! The wrist pin is at a different height in the 2.0 pistons than in the 1.7 or 1.8 ones. Has to do with the way they offset-ground the crank to get the extra 5mm of stroke. There are slip-in 96mm cylinders that fit 1.7 heads. They are super thin, and are generally best avoided. The better idea is, if possible, to have the 1.7 heads milled to fit the 96es that are made for the 1.8 and 2.0 heads. The 1.7 heads have a 100mm "register" where the cylinders fit, which means less than 2mm wall thickness for a 96mm cylinder; the 1.8 and 2.0 heads have 105mm registers so there is a lot more space for the cylinder walls. --DD |
Lo-Fi Version | Time is now: 29th April 2024 - 01:24 PM |
