Time To Do The Engine, Going with a SCAT 2366cc |
7TPorsh |
Jan 15 2019, 04:58 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
Well, car is running like crap and compression is 98-110. Buddy mechanic says there isn't enough there to work with. So need to explore options. Was looking for a 6 awhile ago but that's just too expensive.
I have a 1971 1.7 block (car is 1970), may have bigger cylinders in it but don't know. What are the options if on a slightly restricted budget? I want big and more power but I know there's a tipping point on that. I see new engines advertised here and there. SCAT 2056. Contemplating, do I buy a new engine like this? (any others out there?) or rebuild what I have using a SCAT engine kit or piecing it together using various kits. How big can I easily (budget) go? Currently don't know what I have so assumming a new cam, new crank, etc. I plan on using the existing dual Weber 40IDFs and the MSDS headers/muffler. Here's a pic so there's something visual here. (IMG:style_emoticons/default/beerchug.gif) |
Mayne |
Feb 3 2019, 10:02 AM
Member Group: Members Posts: 254 Joined: 28-February 17 From: NM Member No.: 20,880 Region Association: None |
Spoke to SCAT yesterday. Their 2056 for a 914 is $3900. 2.0 crank, 96mm cans. All new parts. Heads have standard valving. Rated 110hp with webers. They can do a 2366 motor with 103mm cans and bigger valves for $4900. Rated 150 hp with Webers. Both have a 12000/1 year warranty. No core. If i buy all the pieces (crank, cam, cans, etc.) for a 2270 or 2366, how much would it be?...then just have my guy do the work on the existing motor. I’m still interested in hearing more about this endeavor. One thought I have is if the larger stroker motor has more inherent risk, can SCAT build a 2056 but with better head work like they do on the 2366? It’s seems that with the right heads and cam people are getting 130hp from their 2056 motors. So maybe a bit less power but more durability. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 29th April 2024 - 11:54 AM |
