Time To Do The Engine, Going with a SCAT 2366cc |
7TPorsh |
Jan 15 2019, 04:58 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
Well, car is running like crap and compression is 98-110. Buddy mechanic says there isn't enough there to work with. So need to explore options. Was looking for a 6 awhile ago but that's just too expensive.
I have a 1971 1.7 block (car is 1970), may have bigger cylinders in it but don't know. What are the options if on a slightly restricted budget? I want big and more power but I know there's a tipping point on that. I see new engines advertised here and there. SCAT 2056. Contemplating, do I buy a new engine like this? (any others out there?) or rebuild what I have using a SCAT engine kit or piecing it together using various kits. How big can I easily (budget) go? Currently don't know what I have so assumming a new cam, new crank, etc. I plan on using the existing dual Weber 40IDFs and the MSDS headers/muffler. Here's a pic so there's something visual here. (IMG:style_emoticons/default/beerchug.gif) |
Mayne |
Feb 3 2019, 04:29 PM
Member Group: Members Posts: 254 Joined: 28-February 17 From: NM Member No.: 20,880 Region Association: None |
(IMG:style_emoticons/default/agree.gif) a 2366 isnt a stroker motor. (IMG:style_emoticons/default/dry.gif) Right, okay I understand the extra displacement is coming from the 103 pistons and cylinders not from the crank, so I shouldn’t have called it a stroker. But I guess my point, or question, was if the OP had SCAT build him a 2056 but with better head work, could he be content with the power? And would it improve the durability of SCAT motor? Since it seems that the 103 iron cylinders that SCAT suggests are problematic (see below), maybe it would. IMHO the 103's with iron cylinders are a bad choice, over 96mm you need nickies. I'm an engine builder, most of them turn-key and a LN dealer, I won't build an engine with 103 iron cylinders, I would rather (and have) pass on the job. |
Lo-Fi Version | Time is now: 29th April 2024 - 11:48 AM |
