Time To Do The Engine, Going with a SCAT 2366cc |
7TPorsh |
Jan 15 2019, 04:58 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
Well, car is running like crap and compression is 98-110. Buddy mechanic says there isn't enough there to work with. So need to explore options. Was looking for a 6 awhile ago but that's just too expensive.
I have a 1971 1.7 block (car is 1970), may have bigger cylinders in it but don't know. What are the options if on a slightly restricted budget? I want big and more power but I know there's a tipping point on that. I see new engines advertised here and there. SCAT 2056. Contemplating, do I buy a new engine like this? (any others out there?) or rebuild what I have using a SCAT engine kit or piecing it together using various kits. How big can I easily (budget) go? Currently don't know what I have so assumming a new cam, new crank, etc. I plan on using the existing dual Weber 40IDFs and the MSDS headers/muffler. Here's a pic so there's something visual here. (IMG:style_emoticons/default/beerchug.gif) |
Mark Henry |
Feb 4 2019, 08:52 AM
"Cheap-Reliable-Fast, pick two." this 103 mm engine goes into the cheap and fast selection. It will need more frequent rebuilds than a stroked engine with smaller diameter bores or nickies. What is "more frequent" well that all depends on the builder, the owner and the milage and its sortof the X-factor in this combo. One guy might think that tearing the engine apart every 24 months to check the bores for out of round etc is ok, another expects an engine that runs carefree for 10 years. Exactly, I expect my (street) engines to go 60-80K before they need the heads serviced and with proper maintenance 150 -200K being totally realistic. I drive my cars, no garage queens here. Plus I build engines, which means I hate working on my own cars, no fork'in way I'm building an engine that I've got to tear into every 16-20K. To me 103 iron cylinders are a terrible ROI, I'd pick a 2056 or 2270 over an 103 iron jug engine every time. Raby won't build an engine with iron cylinders bigger than 96mm as well. Scat, like a lot of discount/volume builders doesn't care because they don't want to lose a sale, they just want the Benjamins. |
Lo-Fi Version | Time is now: 29th April 2024 - 12:01 PM |
