Time To Do The Engine, Going with a SCAT 2366cc |
7TPorsh |
Jan 16 2019, 11:15 AM
Put new pistons 96's and rebuild the heads. 2k. 1911. Keep everything else the way it is. Get a six....986 or 987 and drive it like you stole it.. Best of both worlds. So 96mm cylinders would equate to 1911? I assume rebuilding the heads dosen't add displacement. WHat is the jump to a 2056? bigger cylinders? Am I buying new cylinders and pistons vs. boring out what I have? Are cam and crank the same? I have carbs and intakes. Unless FI is under $500 I'll stay with the carbs. Would sell the carbs to fund the FI. Not familiar with FI too much. I also have a performance 4 to 1 header from Marty and a Spintech racing muffler so exhaust and intake spoken for. I have an '84 944 for civilized fun. |
7TPorsh |
Jan 16 2019, 11:18 AM
rhodyguy |
Jan 16 2019, 11:38 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,055 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
4-5k? Double your budget. It's the 'while you're in there' factor that kills you. While you're in there, don't forget the new clutch package. Don't presume the flywheel is in spec. Your carbs that function with the 1.7 prob won't deliver the goods with a 2056.
marksteinhilber |
Jan 16 2019, 11:45 AM
Member Group: Members Posts: 229 Joined: 18-October 12 From: Foothill Ranch, CA 92610 Member No.: 15,057 Region Association: Southern California |
Well, car is running like crap and compression is 98-110. Buddy mechanic says there isn't enough there to work with. So need to explore options. Was looking for a 6 awhile ago but that's just too expensive. I have a 1971 1.7 block (car is 1970), may have bigger cylinders in it but don't know. What are the options if on a slightly restricted budget? I want big and more power but I know there's a tipping point on that. I see new engines advertised here and there. SCAT 2056. Contemplating, do I buy a new engine like this? (any others out there?) or rebuild what I have using a SCAT engine kit or piecing it together using various kits. How big can I easily (budget) go? Currently don't know what I have so assumming a new cam, new crank, etc. I plan on using the existing dual Weber 40IDFs and the MSDS headers/muffler. Here's a pic so there's something visual here. (IMG:style_emoticons/default/beerchug.gif) Everyone replied and wants you to spend more of your money than the $3500 2056 SCAT long block that you identified right up front. That is a smart and economic choice which you can always unload for at least a grand with some miles on it. Buy the 2056 and swap it out in a weekend and save your money. Drive the H*** out of it and decide if it isn't enough. You can then play with rebuilding your 1.7 and decide if you want to rebuild it to 2256 or larger by increasing both piston size and stroke. Since it isn't numbers matching and will simply be a tired long block, you can turn it in and buy the completed big bore motor, but it may need bigger carbs, etc. That might cost $5k to $10K from several builders including Fat Perf as mentioned. A real six is quite spendy for even for just a 2.4 or 2.7 and will cost at least $10K to $15K for the engine, rebuild, and the mounts, oil tank, exhaust, etc. Likely even more $$$.... |
BeatNavy |
Jan 16 2019, 12:34 PM
So 96mm cylinders would equate to 1911? I assume rebuilding the heads dosen't add displacement. WHat is the jump to a 2056? bigger cylinders? Am I buying new cylinders and pistons vs. boring out what I have? Are cam and crank the same? I have carbs and intakes. Unless FI is under $500 I'll stay with the carbs. Would sell the carbs to fund the FI. Not familiar with FI too much. 96mm P&C plus the 1.7L crank get you to 1911. If you get a 2.0 Crank (71 mm), you get the 2056. So no, the crank is not the same vs. 1.7. No machining required to drop 96 mm cylinders in (although it might be desirable if the case is out of alignment -- but no boring required). I mentioned $500 as the possible FI cost - what I should have said is you may be able to get a serviceable D-Jet setup for that. As Mark Henry said, anything modern is going to be a good bit more. Lots of good ideas from people. It's up to you based on your budget, desire for power, desire to learn, and desire to get back on the road quickly. I agree with those that say the quickest, cheapest, and easiest route is to buy something that someone already built (either from a place like FAT or from someone who is now looking to go in a different direction from something they previously built/bought). The only real downside to that approach is you don't learn as much and you didn't build it yourself exactly the way you wanted. To some people that matters - others, not so much. |
914_teener |
Jan 16 2019, 02:40 PM
914 Guru Group: Members Posts: 5,193 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
So 96mm cylinders would equate to 1911? I assume rebuilding the heads dosen't add displacement. WHat is the jump to a 2056? bigger cylinders? Am I buying new cylinders and pistons vs. boring out what I have? Are cam and crank the same? I have carbs and intakes. Unless FI is under $500 I'll stay with the carbs. Would sell the carbs to fund the FI. Not familiar with FI too much. 96mm P&C plus the 1.7L crank get you to 1911. If you get a 2.0 Crank (71 mm), you get the 2056. So no, the crank is not the same vs. 1.7. No machining required to drop 96 mm cylinders in (although it might be desirable if the case is out of alignment -- but no boring required). I mentioned $500 as the possible FI cost - what I should have said is you may be able to get a serviceable D-Jet setup for that. As Mark Henry said, anything modern is going to be a good bit more. Lots of good ideas from people. It's up to you based on your budget, desire for power, desire to learn, and desire to get back on the road quickly. I agree with those that say the quickest, cheapest, and easiest route is to buy something that someone already built (either from a place like FAT or from someone who is now looking to go in a different direction from something they previously built/bought). The only real downside to that approach is you don't learn as much and you didn't build it yourself exactly the way you wanted. To some people that matters - others, not so much. Oh...I thought you have a 1.7 now. Now I re-read your post you say you don't know. Tough to say with the 944 that you have....I've got two P cars as well. Busy enough with just upkeep of both to make another project for "more power". If it were I....I'd just rebuild what you have...whatever that is and keep driving it. |
Alphaogre |
Jan 16 2019, 02:57 PM
Member Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California |
I started with a '70 1.7 and built a short stroke 1911 motor with 96mm pistons/jugs, cam and Weber 44s. I love it, its fast revving little motor and so far has been tough too. I've flogged that poor thing at Streets in the summer and that thing just kept going.
If you keep the 1.7 heads you will need some machining, if you are in SoCal there are shops that build these motors really well for Baja, so they know reliability and power. I'd say, with custom ordering a cam, the machining, and getting Keith Black Hypereutectic pistons plus the ancillary stuff it was around $2300... I had the carbs before as they came with the car when I got it... |
VaccaRabite |
Jan 17 2019, 10:33 AM
En Garde! Group: Admin Posts: 13,420 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
From your 1.7:
96mm P&C will get you to 1911. 96mm P&C and 2.0 Crank will get you to a 2056. 96mm P&C, stroker crank will get you to a 2270 (but you will need to replace about everything and probably spend a good bit more then your budget doing it). My 2056 was built on a 1.7 case. You will spend most of your budget on heads. And that's okay. I don't know that you can get your heads reworked for 2K any more (or even if you should), but you can buy new ones for about 4K. My 2056 dynoed at close to 150HP (127 at the wheels). Its FUN. But also has more goodies on it. Just doing P&C and heads will get you to about 115, which will also be fun and quicker then your current 1.7 by a ton. |
BeatNavy |
Jan 17 2019, 11:37 AM
You will spend most of your budget on heads. And that's okay. I don't know that you can get your heads reworked for 2K any more (or even if you should), but you can buy new ones for about 4K. I purchased the AAP heads from HAM (Len Hoffman). All in with Len doing his magic, and ceramic coating the combustion chambers, well under $2k. Len's done a few sets of these. We don't have the data yet on how well these AAP heads will hold up over time, but...the price is attractive, and Len's initial impressions of them were not bad. |
bbrock |
Jan 17 2019, 11:42 AM
You will spend most of your budget on heads. And that's okay. I don't know that you can get your heads reworked for 2K any more (or even if you should), but you can buy new ones for about 4K. Just for a point of reference on this. I sent my 2.0 heads to Dave Bonbright last Spring for a basic rework. I supplied new springs and guides and he did a basic refresh with new SS valves for $800. That included extracting a couple broken exhaust studs which he said added up. |
7TPorsh |
Jan 18 2019, 12:04 PM
Thanks Guys, this is really great info.
So it looks like I will be deciding between a 1911 and a 2056. To verify, it sounds like at a base, both will require 96mm cans. And if I go to 2056 will I only need a 71mm crank and related connecting rods? So I'm getting 145cc just by changing crank and rods? I see 96mm PCs from cast iron to alluminum, etc. Will I feel a difference with aluminum all other things remaining equal? I'd like to keep the car more on the bullet-proof side vs. touchy. Who has the best deal around? in either case, will I need to open up the heads to 96mm? Is it called bore? Someone mentioned enlarging valves. Would this be only in the 2056 scenario or could do to a 1911. I anticipate that kind of headwork would be expensive. I am seeing a trend for basic headwork at around $700-800. |
Jan 18 2019, 12:21 PM
914-6 GT in waiting Group: Members Posts: 19,223 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
What is your budget. $5k, 7.5k, 10k?
nditiz1 |
Jan 18 2019, 12:36 PM
Senior Member Group: Members Posts: 1,177 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
So I feel there are two routes I would go in your shoes. Source the parts to make a 2056. If you shop right you can stay within budget ($4-5k)
As mentioned heads could be the greatest money item as they should be. Don't scimp here and the motor should last. Len's ran me ~$1450. Option 2 which is way easier in my mind is have an already built 2056 from McMark. I think his packages fall within the 4-5 range for a 2056. These are Raby builds allowed to be be built by McMark. You can go FI or Carbs, your choice. I think his builds were Dynoing around 125hp. Drop it in and go. |
burton73 |
Jan 18 2019, 02:13 PM
burton73 Group: Members Posts: 3,486 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
From the LOGO:
"I got a plug and play big/4 engine (seller says it was a 12k build) from a member here for 5k And it worked out great . Much happier then a rebuild . And 3x as fast/powerful . Had the 1.7 rebuilt while outta the car and considering going back to stock . Id let the big /4 go for 5500$(complete package ,plug and play) and if you want to come see it run and ride in the car before buying , that would not be a problem. Since im in monrovia let me know . Got the engine and had my fun with it , i think its got about 5k miles on it ." This may be the best shot. Plug and play and you can sell your running Eng. to someone. and you can test it out. Waiting for an engine can be a bitch. Bob B |
Al Meredith |
Jan 18 2019, 05:04 PM
Senior Member Group: Members Posts: 958 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
with the 2056 you not only get the added CCs but the longer stroke gives you a larger increase in torque. I love my 2056 . look for a 2.0 crank and rods.
Jan 18 2019, 06:39 PM
914 Idiot Group: Members Posts: 14,980 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
So it looks like I will be deciding between a 1911 and a 2056. To verify, it sounds like at a base, both will require 96mm cans. And if I go to 2056 will I only need a 71mm crank and related connecting rods? So I'm getting 145cc just by changing crank and rods? Pistons, too! The wrist pin is at a different height in the 2.0 pistons than in the 1.7 or 1.8 ones. Has to do with the way they offset-ground the crank to get the extra 5mm of stroke. There are slip-in 96mm cylinders that fit 1.7 heads. They are super thin, and are generally best avoided. The better idea is, if possible, to have the 1.7 heads milled to fit the 96es that are made for the 1.8 and 2.0 heads. The 1.7 heads have a 100mm "register" where the cylinders fit, which means less than 2mm wall thickness for a 96mm cylinder; the 1.8 and 2.0 heads have 105mm registers so there is a lot more space for the cylinder walls. --DD |
wndsrfr |
Jan 18 2019, 09:17 PM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
From the LOGO: "I got a plug and play big/4 engine (seller says it was a 12k build) from a member here for 5k And it worked out great . Much happier then a rebuild . And 3x as fast/powerful . Had the 1.7 rebuilt while outta the car and considering going back to stock . Id let the big /4 go for 5500$(complete package ,plug and play) and if you want to come see it run and ride in the car before buying , that would not be a problem. Since im in monrovia let me know . Got the engine and had my fun with it , i think its got about 5k miles on it ." This may be the best shot. Plug and play and you can sell your running Eng. to someone. and you can test it out. Waiting for an engine can be a bitch. Bob B (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) Jump on this one...if it includes induction and exhaust headers it's a gift! (No affiliation) |
tmessenger |
Jan 18 2019, 09:49 PM
Member Group: Members Posts: 70 Joined: 6-December 18 From: Iowa Member No.: 22,707 Region Association: Upper MidWest |
913B |
Jan 20 2019, 12:09 PM
Senior Member Group: Members Posts: 843 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
My apologies in advance for the highjack.
Without bashing Scat too much. What is wrong with their 2056 motor for only $3600 (IMG:style_emoticons/default/confused24.gif) |
VaccaRabite |
Jan 24 2019, 09:38 AM
My apologies in advance for the highjack. Without bashing Scat too much. What is wrong with their 2056 motor for only $3600 (IMG:style_emoticons/default/confused24.gif) The issue is that you can't buy the parts for that much, so you know that they are cutting corners or using bargain basement parts from China. In all likelihood they are only adding larger P&C to an otherwise stock engine, maybe doing some cleanup. You would hope that at least they are checking bearings, and balancing parts - but you don't know and if they can build an engine without splitting the case that's profit in the bank for them. I can all but promise you the engine will either be using only cleaned up heads or the AMC heads with shit hardware. Its a dice roll. For a car that only gets driven a few miles a year, or sits idle in a garage for years at a time before the engine even goes in... that engine may last 5 or 10 years. Or... roll those dice. Zach |
Lo-Fi Version | Time is now: 19th April 2024 - 07:57 PM |
