Ivory 1970 914/6 Build, Shake down before delivery |
gms |
Jan 15 2019, 09:06 PM
Advanced Member Group: Members Posts: 2,694 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
gms |
Mar 27 2019, 08:43 PM
sixnotfour |
Mar 27 2019, 09:12 PM
914 Wizard Group: Members Posts: 10,411 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
gms |
Mar 27 2019, 09:33 PM
Luke M |
Mar 28 2019, 09:36 AM
Senior Member Group: Members Posts: 1,369 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I wish I had some for myself I thought 914rubber makes these brushes now? I need a set for my 6 as well. Glenn, on the Kroon wire harness did you notice if the wire diameter was different then the factory ? I'm sending a harness off to Kroon to have redone for my 6. In emailing with Gerard, he mentioned only difference would be in some connectors. Did you happen to notice any difference ? Keep up the updates... |
gms |
Mar 29 2019, 12:02 PM
I thought 914rubber makes these brushes now? I need a set for my 6 as well. I did not notice them on the website, anyone see them? Glenn, on the Kroon wire harness did you notice if the wire diameter was different then the factory ? I'm sending a harness off to Kroon to have redone for my 6. In emailing with Gerard, he mentioned only difference would be in some connectors. Did you happen to notice any difference ? Keep up the updates... I will check |
altitude411 |
Mar 29 2019, 12:52 PM
I drove my 6 into a tree Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains |
I thought 914rubber makes these brushes now? I did not notice them on the website, anyone see them? Glenn, 914Rubber shows them on the early headlight rebuild kit but I don't see them sold separately. (IMG:style_emoticons/default/confused24.gif) https://900designs-container.zoeysite.com/e...ght-rebuild-kit @Mikey914 |
Lo-Fi Version | Time is now: 26th April 2024 - 04:44 PM |
