Uneven tire to fender clearance from side to side |
Tdskip |
Jan 18 2019, 12:14 PM
Good morning. There is a bright orange yellow orb in the sky over Southern California right now. Quite welcome to see it, but I digress.
The 1974 Arizona car has uneven tire to fender clearance from side to side. The tires are the same make and size, it has the same rims on it, but I have about one fingers worth of clearance on the driver side to the tire wall but basically none on the passenger side. I don’t have a history on the car but the tub is straight and does not evidence any accidents. I haven’t put the car up on a rack to check the alignment but it doesn’t look like the rear camber is noticeably different from side to side. Any ideas to share? Thanks! |
SirAndy |
Jan 18 2019, 01:20 PM
Resident German Group: Admin Posts: 41,641 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
While there may be small variations from the factory, a whole finger width is concerning.
A few things to check: - Make sure the fenders aren't dented - Make sure the inside fender lips are the same, one could be rolled while the other isn't - The alignment could be off from side to side. Check the camber on each side. - Trailing arm bushings shot - The trailing arm(s) could be bent. Seen this before. Check for unequal amounts of alignment shims side to side. - Rust in the suspension console or cracked suspension console, both of which will allow the trailing arm to move around. - Bent wheel, loose lug nuts or lose wheel bearing (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 07:47 PM |
