Uneven tire to fender clearance from side to side |
Tdskip |
Jan 18 2019, 12:14 PM
Good morning. There is a bright orange yellow orb in the sky over Southern California right now. Quite welcome to see it, but I digress.
The 1974 Arizona car has uneven tire to fender clearance from side to side. The tires are the same make and size, it has the same rims on it, but I have about one fingers worth of clearance on the driver side to the tire wall but basically none on the passenger side. I don’t have a history on the car but the tub is straight and does not evidence any accidents. I haven’t put the car up on a rack to check the alignment but it doesn’t look like the rear camber is noticeably different from side to side. Any ideas to share? Thanks! |
914_teener |
Jan 18 2019, 02:01 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
One thing that is not mentioned is worn trailing arm bushings.
Usually they wear most on the drivers side. Check for this by jacking the car up...grab the (rear) wheel at the 3 and 9 oclock position and check for play. |
Lo-Fi Version | Time is now: 17th May 2024 - 07:22 PM |
