> Can I use a Carter’s inline pump AND a fuel return line?, Or do I need a three port pump?
tornik550
post Jan 19 2019, 03:48 PM
I recently changed to PMO carbs. I have the PMO fuel pressure regulator which calls for the use of the fuel return line. I previously had used a Carter inline pump and did not have the return line hooked up.
I am installing new metal fuel lines from tangerine. I figure that if I am replacing lines, I might as well replace the return line also (even if I don’t use it).
My question is- can I use the same carters inline pump and also use the fuel return line or do I have to get a fuel pump that has a return port? I have never used a fuel return line so I have a poor understanding of its function- I am not clear if any sort of pump pressure is needed to get the fuel to return?
Mark Henry
post Jan 19 2019, 03:52 PM
that's what I do!
The return comes off of PMO regulator.
One in from pump, one out (return) and two to the carbs, one for each carb.
tornik550
post Jan 19 2019, 04:05 PM
So do I run the line directly from the pmo regulator up front to the fuel tank?
mb911
post Jan 19 2019, 04:07 PM
QUOTE(tornik550 @ Jan 19 2019, 02:05 PM) *
Yes and That's what I am doing on my test standAttached Image
Mark Henry
post Jan 19 2019, 07:50 PM
that's what I do!
Interested in a mount for the PMO regulator?
Needs no holes drilled into the car. Easy to see the gauge and adjust the pressure.
I'm thinking $35 shipping included.
I'll post some pics later tonight.
Mark Henry
post Jan 19 2019, 10:02 PM
that's what I do!
My PMO mount. (IMG:style_emoticons/default/smile.gif)
- Lo-Fi Version Time is now: 15th April 2024 - 11:24 PM
