Can I use a Carter’s inline pump AND a fuel return line?, Or do I need a three port pump? |
tornik550 |
Jan 19 2019, 03:48 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I recently changed to PMO carbs. I have the PMO fuel pressure regulator which calls for the use of the fuel return line. I previously had used a Carter inline pump and did not have the return line hooked up.
I am installing new metal fuel lines from tangerine. I figure that if I am replacing lines, I might as well replace the return line also (even if I don’t use it). My question is- can I use the same carters inline pump and also use the fuel return line or do I have to get a fuel pump that has a return port? I have never used a fuel return line so I have a poor understanding of its function- I am not clear if any sort of pump pressure is needed to get the fuel to return? |
Mark Henry |
Jan 19 2019, 03:52 PM
The return comes off of PMO regulator.
One in from pump, one out (return) and two to the carbs, one for each carb. |
Lo-Fi Version | Time is now: 16th May 2024 - 08:48 AM |
