Replacing steering coupler |
PanelBilly |
Jan 21 2019, 09:52 AM
914 Guru Group: Members Posts: 5,805 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Do I need to drop the front suspension to replace the coupler?
Mikey914 |
Jan 21 2019, 11:11 AM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
If you mean the "puck" no you don't have to drop it all. You need to disconnect the ends from the rack, the 2 bolts holding it on and the upper knuckle that goes to the steering wheel.
DO pay attention to the upper yoke as to the side with the notch and have a 50 /50 chance of putting it back on backwards. If you do this you can pull the steering wheel to re align the wheel, but easier to get it right the 1st time. This piece. Have new upper bearings (with new rubber), as well as the washers, if you need them too. https://shop.914rubber.com/Steering-bearing...m?categoryId=-1 Attached thumbnail(s) Attached image(s) |
914Sixer |
Jan 21 2019, 10:15 PM
Don't forget to bend the locking tabs up. You do not want the bolts backing out.
Lo-Fi Version | Time is now: 14th May 2024 - 01:00 AM |
