Momo Tuner Steering wheel |
soccerplyr |
Jan 27 2019, 11:00 AM
Newbie Group: Members Posts: 25 Joined: 31-August 13 From: Sandy, Utah Member No.: 16,329 Region Association: Rocky Mountains |
Does anyone have this Momo in their car? I'm curious what spacers are being used. The one that came with my car isn't long enough. My knuckles hit the windshield wiper lever.
Attached thumbnail(s) Attached image(s) |
windforfun |
Jan 27 2019, 11:19 AM
Senior Member Group: Members Posts: 1,779 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
That looks fantastic! Did you visit their website?
oakdalecurtis |
Jan 27 2019, 11:25 AM
Oakdalecurtis Group: Members Posts: 1,325 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
You may want to get a JSWest eccentric spacer. The spacer is about 3/4 of an inch thick and it also lifts the steering wheel about a half inch, giving you more legroom below and an improved view of your dash gauges. Here's the part website and before and after pics of dash view.
http://www.jwesteng.com/shop/home/15-steer...ic-adapter.html |
soccerplyr |
Jan 27 2019, 01:14 PM
You may want to get a JSWest eccentric spacer. The spacer is about 3/4 of an inch thick and it also lifts the steering wheel about a half inch, giving you more legroom below and an improved view of your dash gauges. Here's the part website and before and after pics of dash view. http://www.jwesteng.com/shop/home/15-steer...ic-adapter.html The website is pretty worthless. I'll check out the jwest part, would be nice to see the gauges as well. Thanks for the suggestion oakdalecurtis. |
sixnotfour |
Jan 27 2019, 01:25 PM
914 Wizard Group: Members Posts: 10,423 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
1/2 inch to 1 inch spacers ..ebay amazon..
Steve |
Jan 27 2019, 01:29 PM
914 Guru Group: Members Posts: 5,580 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I had the same problem. Curious if this is a stock windshield wiper switch or the 924 one with the electric washer hookup. I had the same problem when I switched to the 924 one. I wonder if the angle is different? Otherwise the JWest offset or the 1/2” Momo spacer will solve the problem.
mlindner |
Jan 27 2019, 01:33 PM
Senior Member Group: Members Posts: 1,518 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
I think the issue is with the flat wheels, a number of the wheels are dished bringing the grip area out an inch or so. Mark
oakdalecurtis |
Jan 27 2019, 02:12 PM
Sorry, this link should work to the JS West Eccentric adaptor:
http://www.jwesteng.com/shop/914/15-steeri...c-adapter.html# |
Lo-Fi Version | Time is now: 8th May 2024 - 06:49 PM |
