75 Brake Warning Light, The brake warning light on the combo gauge is flashing |
dennisphelan |
Jan 28 2019, 12:56 PM
Newbie Group: Members Posts: 15 Joined: 10-December 18 From: Dundee Oregon Member No.: 22,713 Region Association: Pacific Northwest |
The large red brake warning light on the combo gauge is flashing. The emergency brake is disengaged. I checked the brake master cylinder and the one wire ( it only has one connection) that goes to it is attached. It appears I have some fluid leaking as the connection was wet with fluid. The car hasn't been driven in 12 years so I am sure many things could be wrong. What is the switch on the master cylinder sensing?
Thanks, Dennis Phelan |
pvollma |
Jan 29 2019, 11:21 AM
Member Group: Members Posts: 205 Joined: 12-May 13 From: Camp Hill, PA Member No.: 15,862 Region Association: MidAtlantic Region |
The large red brake warning light on the combo gauge is flashing. The emergency brake is disengaged. I checked the brake master cylinder and the one wire ( it only has one connection) that goes to it is attached. It appears I have some fluid leaking as the connection was wet with fluid. The car hasn't been driven in 12 years so I am sure many things could be wrong. What is the switch on the master cylinder sensing? When I first picked up my new-to-me 76, the light would continue to flash after releasing the handbrake. I found that pulling it up again and then forcefully pushing it down with the release button pressed would cancel the warning light. The PO had let the car sit for a long time while he worked on it, so I suspect something in the switch that senses the handle position was hung up or corroded. After a few weeks of using this method, it was no longer needed, but, of course, YMMV. |
Lo-Fi Version | Time is now: 6th May 2024 - 04:52 PM |
