75 Brake Warning Light, The brake warning light on the combo gauge is flashing |
dennisphelan |
Jan 28 2019, 12:56 PM
Newbie Group: Members Posts: 15 Joined: 10-December 18 From: Dundee Oregon Member No.: 22,713 Region Association: Pacific Northwest |
The large red brake warning light on the combo gauge is flashing. The emergency brake is disengaged. I checked the brake master cylinder and the one wire ( it only has one connection) that goes to it is attached. It appears I have some fluid leaking as the connection was wet with fluid. The car hasn't been driven in 12 years so I am sure many things could be wrong. What is the switch on the master cylinder sensing?
Thanks, Dennis Phelan |
914_teener |
Jan 28 2019, 01:47 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
The large red brake warning light on the combo gauge is flashing. The emergency brake is disengaged. I checked the brake master cylinder and the one wire ( it only has one connection) that goes to it is attached. It appears I have some fluid leaking as the connection was wet with fluid. The car hasn't been driven in 12 years so I am sure many things could be wrong. What is the switch on the master cylinder sensing? Thanks, Dennis Phelan A failed MC. So it is probably rusted and the light is doing what it is supposed to. Edit: Or switch is rusted. You don't mention if the brakes work....have a peal and stop the car or not. Need lot's more info. Good Luck. |
914_teener |
Aug 14 2019, 09:56 AM
The large red brake warning light on the combo gauge is flashing. The emergency brake is disengaged. I checked the brake master cylinder and the one wire ( it only has one connection) that goes to it is attached. It appears I have some fluid leaking as the connection was wet with fluid. The car hasn't been driven in 12 years so I am sure many things could be wrong. What is the switch on the master cylinder sensing? Thanks, Dennis Phelan A failed MC. So it is probably rusted and the light is doing what it is supposed to. Edit: Or switch is rusted. You don't mention if the brakes work....have a peal and stop the car or not. Need lot's more info. Good Luck. So ......admins.....Ii didn't post this. Very weird. |
Lo-Fi Version | Time is now: 6th May 2024 - 06:57 AM |
