Sub Woofer Installation, Tried to get better Audio without carving up the car |
ctc911ctc |
Jan 28 2019, 06:42 PM
Senior Member Group: Members Posts: 890 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
All,
Been silent, very cold - garage is a 100 year old Yankee version, no heat.....will not hold any. So, my 17yr old son and I decided to upgrade the speakers (the old ones were absent any cone material). Found a set of KFC-4675C (kenwood) that fit the spec, integrated mid range and tweeter. Now for the low range. We decided that carving up the car and running a large alternator and battery was not for this car, we are trying to restore it to 80-90 points. So we are using a passive crossover, the original tuner with a power amp that was installed in the 80s, still works (both units are Blauplunkt). We have about 40 watts - more than enough for the size of the car. When we rebuilt the car we installed sound deadening material in the engine bay, passenger compartment and will put it in the trunk. Amazing how quiet the car seems in the passenger compartment now. My son had the idea to install the Subwoofer in the engine compartment, cut through the back seat - had to explain the concept of FireWall to him, we looked at a dozen other places and settled on what I think is a very elegant solution. Our car is a '74 2.0, Silver. So it has a center console. We are installing it there! First, where should the speaker go???? Wow - no particle board - furniture grade ply! Peel back the Vinyl, careful! Counter sync for flush hidden finish Score the vinyl, perhaps we can STRETCH it! Heat gun and PULL, gently Look at that circle, no wood showing, barely a wrinkle! Add a screen Bolt that Micro SubWoofer in place What the Passenger will see Perfect Fit Passive Crossover Will post a note as to how this sounds in a few weeks (months?) Attached image(s) |
Mikey914 |
Jan 29 2019, 02:00 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Nice work, but to get decent sound you need to box it in. I’ll post some pics of the one we do so you can see it.
Mark |
ctc911ctc |
Jan 29 2019, 09:01 AM
Nice work, but to get decent sound you need to box it in. I’ll post some pics of the one we do so you can see it. Mark Hey Mikey, As to the BOX, the passenger compartment is box enough! At the frequency range we are at, we do not need projection just coupling. Will post how it sounds, just trying to fill in the 100-1000. I read that you made these? could not find them on your site.. Link please? CTC911CTC |
amfab |
Jan 29 2019, 10:37 AM
Member Group: Members Posts: 391 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
Nice work, but to get decent sound you need to box it in. I’ll post some pics of the one we do so you can see it. Mark Hey Mikey, As to the BOX, the passenger compartment is box enough! At the frequency range we are at, we do not need projection just coupling. Will post how it sounds, just trying to fill in the 100-1000. I read that you made these? could not find them on your site.. Link please? CTC911CTC If it is not a sealed or ported box you will be putting negative and positive pressure into the box of the passenger compartment simultaneously and the pressure waves will cancel each other out below the frequency at which the open console acts as a small baffle. -Andrew |
ctc911ctc |
Jan 29 2019, 04:44 PM
Nice work, but to get decent sound you need to box it in. I’ll post some pics of the one we do so you can see it. Mark Hey Mikey, As to the BOX, the passenger compartment is box enough! At the frequency range we are at, we do not need projection just coupling. Will post how it sounds, just trying to fill in the 100-1000. I read that you made these? could not find them on your site.. Link please? CTC911CTC If it is not a sealed or ported box you will be putting negative and positive pressure into the box of the passenger compartment simultaneously and the pressure waves will cancel each other out below the frequency at which the open console acts as a small baffle. -Andrew Not too concerned, coupling will be ok, Lamda is large, blocking is present. Thanks, will let you know how it works. CTC911CTC |
Lo-Fi Version | Time is now: 24th April 2024 - 01:32 AM |
