Sub Woofer Installation, Tried to get better Audio without carving up the car |
ctc911ctc |
Jan 28 2019, 06:42 PM
Senior Member Group: Members Posts: 890 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
All,
Been silent, very cold - garage is a 100 year old Yankee version, no heat.....will not hold any. So, my 17yr old son and I decided to upgrade the speakers (the old ones were absent any cone material). Found a set of KFC-4675C (kenwood) that fit the spec, integrated mid range and tweeter. Now for the low range. We decided that carving up the car and running a large alternator and battery was not for this car, we are trying to restore it to 80-90 points. So we are using a passive crossover, the original tuner with a power amp that was installed in the 80s, still works (both units are Blauplunkt). We have about 40 watts - more than enough for the size of the car. When we rebuilt the car we installed sound deadening material in the engine bay, passenger compartment and will put it in the trunk. Amazing how quiet the car seems in the passenger compartment now. My son had the idea to install the Subwoofer in the engine compartment, cut through the back seat - had to explain the concept of FireWall to him, we looked at a dozen other places and settled on what I think is a very elegant solution. Our car is a '74 2.0, Silver. So it has a center console. We are installing it there! First, where should the speaker go???? Wow - no particle board - furniture grade ply! Peel back the Vinyl, careful! Counter sync for flush hidden finish Score the vinyl, perhaps we can STRETCH it! Heat gun and PULL, gently Look at that circle, no wood showing, barely a wrinkle! Add a screen Bolt that Micro SubWoofer in place What the Passenger will see Perfect Fit Passive Crossover Will post a note as to how this sounds in a few weeks (months?) Attached image(s) |
dr914@autoatlanta.com |
Jan 29 2019, 12:09 PM
914 Guru Group: Members Posts: 7,811 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
best to put the sub woofer where the passenger foam block under the bulkhead carpet rests. Works perfectly, cannot tell any difference in the interior appearance:
horizontally-opposed |
Jan 29 2019, 04:25 PM
Advanced Member Group: Members Posts: 3,430 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
best to put the sub woofer where the passenger foam block under the bulkhead carpet rests. Works perfectly, cannot tell any difference in the interior appearance: If someone makes a box for this—which lost no legroom, I'm interested. Much more appealing than the center console, as it could end up invisible (and I don't have a center console in my car, something I suspect is true for many 914s). Even a mild bass "box/tube" that was well designed and didn't eat up any more legroom than the foam block would be a nice improvement. |
drem914 |
Jan 29 2019, 05:11 PM
Senior Member Group: Members Posts: 1,027 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
best to put the sub woofer where the passenger foam block under the bulkhead carpet rests. Works perfectly, cannot tell any difference in the interior appearance: If someone makes a box for this—which lost no legroom, I'm interested. Much more appealing than the center console, as it could end up invisible (and I don't have a center console in my car, something I suspect is true for many 914s). Even a mild bass "box/tube" that was well designed and didn't eat up any more legroom than the foam block would be a nice improvement. The sub box you seek is available at 914Rubber.com and a vendor on ebay. Just look up Porsche 914 subwoofer. covered in black or grey perlon, fits an 8" sub. |
Jan 29 2019, 08:35 PM
The sub box you seek is available at 914Rubber.com and a vendor on ebay. Just look up Porsche 914 subwoofer. covered in black or grey perlon, fits an 8" sub. Was just all over 914rubber.com...have to say it was a bit tough to navigate, but could not find speaker enclosures—this after finding the link that promised them... https://shop.914rubber.com/Body-Parts_c38.htm Have a better link? Or...Mikey? Thanks! pete |
Lo-Fi Version | Time is now: 20th April 2024 - 03:02 AM |
