Sub Woofer Installation, Tried to get better Audio without carving up the car |
ctc911ctc |
Jan 28 2019, 06:42 PM
Senior Member Group: Members Posts: 890 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
All,
Been silent, very cold - garage is a 100 year old Yankee version, no heat.....will not hold any. So, my 17yr old son and I decided to upgrade the speakers (the old ones were absent any cone material). Found a set of KFC-4675C (kenwood) that fit the spec, integrated mid range and tweeter. Now for the low range. We decided that carving up the car and running a large alternator and battery was not for this car, we are trying to restore it to 80-90 points. So we are using a passive crossover, the original tuner with a power amp that was installed in the 80s, still works (both units are Blauplunkt). We have about 40 watts - more than enough for the size of the car. When we rebuilt the car we installed sound deadening material in the engine bay, passenger compartment and will put it in the trunk. Amazing how quiet the car seems in the passenger compartment now. My son had the idea to install the Subwoofer in the engine compartment, cut through the back seat - had to explain the concept of FireWall to him, we looked at a dozen other places and settled on what I think is a very elegant solution. Our car is a '74 2.0, Silver. So it has a center console. We are installing it there! First, where should the speaker go???? Wow - no particle board - furniture grade ply! Peel back the Vinyl, careful! Counter sync for flush hidden finish Score the vinyl, perhaps we can STRETCH it! Heat gun and PULL, gently Look at that circle, no wood showing, barely a wrinkle! Add a screen Bolt that Micro SubWoofer in place What the Passenger will see Perfect Fit Passive Crossover Will post a note as to how this sounds in a few weeks (months?) Attached image(s) |
Mark Henry |
Jan 14 2020, 07:39 AM
So hacking on the interior, I don't want to cut the carpet for the foot box so obviously this is no go for me. I didn't really want a console but for me it looks like the only solution.
I think I'll also look at having a go at a homebuilt console. I'm not going to hack up the console I have, but I can use it for a pattern. I already have the black vinyl and I just inherited my mom's Bernina sewing machine, so maybe it's a good time to learn how to use it. What about a round one inch spacer between the speaker and console box? That could give a bit more interior volume and likely not interfere much in the passenger footwell. |
horizontally-opposed |
Jan 14 2020, 12:37 PM
Advanced Member Group: Members Posts: 3,430 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
So hacking on the interior, I don't want to cut the carpet for the foot box so obviously this is no go for me. I didn't really want a console but for me it looks like the only solution. I think I'll also look at having a go at a homebuilt console. I'm not going to hack up the console I have, but I can use it for a pattern. I already have the black vinyl and I just inherited my mom's Bernina sewing machine, so maybe it's a good time to learn how to use it. What about a round one inch spacer between the speaker and console box? That could give a bit more interior volume and likely not interfere much in the passenger footwell. I had a Kenwood bass wedge in the passenger footwell years ago with a piece of plywood over it...all in lieu of the factory's "wasteful" foam wedge filler used to build out a nice place for the passenger's feet. It worked pretty well, and wasn't obvious visually but it really cut down on passenger legroom...so I removed it. If I had a center console, or wanted one, the solution in this thread would be my go-to, but I'd dearly love a fiberglass box made to fit the 914 footwell like the factory foam while maximizing air space (upward? or to the right) and properly ported. I'd be interested in something like this if it meant running a smaller bass driver. Some of the home speakers these days make amazing bass from small packages. I wonder if there is even a way to "double port" it to the front trunk for more volume, but must confess I don't know how bass works in that regard. Not sure making one as a one off makes sense, but it seems like a wonderful product for 914rubber if it's relatively easy to do. Could be furnished in raw fiberglass, and would be instantly reversible if the factory foam block is stored in the garage. |
Lo-Fi Version | Time is now: 24th April 2024 - 06:33 PM |
