Sub Woofer Installation, Tried to get better Audio without carving up the car |
ctc911ctc |
Jan 28 2019, 06:42 PM
Senior Member Group: Members Posts: 885 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
All,
Been silent, very cold - garage is a 100 year old Yankee version, no heat.....will not hold any. So, my 17yr old son and I decided to upgrade the speakers (the old ones were absent any cone material). Found a set of KFC-4675C (kenwood) that fit the spec, integrated mid range and tweeter. Now for the low range. We decided that carving up the car and running a large alternator and battery was not for this car, we are trying to restore it to 80-90 points. So we are using a passive crossover, the original tuner with a power amp that was installed in the 80s, still works (both units are Blauplunkt). We have about 40 watts - more than enough for the size of the car. When we rebuilt the car we installed sound deadening material in the engine bay, passenger compartment and will put it in the trunk. Amazing how quiet the car seems in the passenger compartment now. My son had the idea to install the Subwoofer in the engine compartment, cut through the back seat - had to explain the concept of FireWall to him, we looked at a dozen other places and settled on what I think is a very elegant solution. Our car is a '74 2.0, Silver. So it has a center console. We are installing it there! First, where should the speaker go???? Wow - no particle board - furniture grade ply! Peel back the Vinyl, careful! Counter sync for flush hidden finish Score the vinyl, perhaps we can STRETCH it! Heat gun and PULL, gently Look at that circle, no wood showing, barely a wrinkle! Add a screen Bolt that Micro SubWoofer in place What the Passenger will see Perfect Fit Passive Crossover Will post a note as to how this sounds in a few weeks (months?) Attached image(s) |
bbrock |
Mar 26 2020, 10:49 PM
Thought I would report that the JL Audio sub mentioned earlier in this thread does NOT fit as a stealth installation. The magnet is just about 1/4" too large in diameter to fit into the footwell foam space. If you are willing to give up about an inch of footwell space, it would work, but I'm not. I'm sending mine back and will get one of these instead:
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.crutchfieldonline.com-20845-1585284551.1.jpeg) https://www.crutchfield.com/p_575P3SD28/Roc...8.html?tp=68847 The JL sounded really nice though. Even just using a cardboard box for an enclosure, it paired very nicely with my Infinity speakers. @Mikey914 Any progress on those enclosures? Will there be a sealed enclosure option? I'm guessing the port could be sealed up easy enough, but curious. |
Mikey914 |
Mar 27 2020, 09:11 AM
The rubber man Group: Members Posts: 12,622 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Thought I would report that the JL Audio sub mentioned earlier in this thread does NOT fit as a stealth installation. The magnet is just about 1/4" too large in diameter to fit into the footwell foam space. If you are willing to give up about an inch of footwell space, it would work, but I'm not. I'm sending mine back and will get one of these instead: (IMG:http://www.914world.com/bbs2/uploads_offsite/images.crutchfieldonline.com-20845-1585284551.1.jpeg) https://www.crutchfield.com/p_575P3SD28/Roc...8.html?tp=68847 The JL sounded really nice though. Even just using a cardboard box for an enclosure, it paired very nicely with my Infinity speakers. @Mikey914 Any progress on those enclosures? Will there be a sealed enclosure option? I'm guessing the port could be sealed up easy enough, but curious. Actually, Been a bit busy at the day job working as many hours as they will let me. These are still on the list, but just on hold for a bit. mark |
Lo-Fi Version | Time is now: 28th March 2024 - 10:46 AM |
