Sub Woofer Installation, Tried to get better Audio without carving up the car |
ctc911ctc |
Jan 28 2019, 06:42 PM
Senior Member Group: Members Posts: 890 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
All,
Been silent, very cold - garage is a 100 year old Yankee version, no heat.....will not hold any. So, my 17yr old son and I decided to upgrade the speakers (the old ones were absent any cone material). Found a set of KFC-4675C (kenwood) that fit the spec, integrated mid range and tweeter. Now for the low range. We decided that carving up the car and running a large alternator and battery was not for this car, we are trying to restore it to 80-90 points. So we are using a passive crossover, the original tuner with a power amp that was installed in the 80s, still works (both units are Blauplunkt). We have about 40 watts - more than enough for the size of the car. When we rebuilt the car we installed sound deadening material in the engine bay, passenger compartment and will put it in the trunk. Amazing how quiet the car seems in the passenger compartment now. My son had the idea to install the Subwoofer in the engine compartment, cut through the back seat - had to explain the concept of FireWall to him, we looked at a dozen other places and settled on what I think is a very elegant solution. Our car is a '74 2.0, Silver. So it has a center console. We are installing it there! First, where should the speaker go???? Wow - no particle board - furniture grade ply! Peel back the Vinyl, careful! Counter sync for flush hidden finish Score the vinyl, perhaps we can STRETCH it! Heat gun and PULL, gently Look at that circle, no wood showing, barely a wrinkle! Add a screen Bolt that Micro SubWoofer in place What the Passenger will see Perfect Fit Passive Crossover Will post a note as to how this sounds in a few weeks (months?) Attached image(s) |
bbrock |
May 5 2020, 12:35 PM
Posted this on my build thread a month ago but figured I'd update here. I think the Rockford-Fosgate sub will work in the foot well location. I just have it mounted on a cheezie temporary board for not until I can get that awesome enclosure Mark is working on (IMG:style_emoticons/default/poke.gif)
(IMG:http://www.914world.com/bbs2/uploads/post-20845-1586067181_thumb.jpg) With the enclosure, I'll rig a flush mount with a sturdy grill to keep feet from poking through. I might have to sacrifice about 1/2" of foot space to make it completely flush but won't know for sure until I have the box. Even with the cobbled setup, it is pretty stealth. (IMG:http://www.914world.com/bbs2/uploads/post-20845-1586067451_thumb.jpg) Sound-wise, I liked the JL Audio sub better but this is pretty nice after it got broken in a little. It's a bit wimpy running free-air on that board though so I'm really looking forward to having an enclosure so I can button this up. |
horizontally-opposed |
May 5 2020, 01:19 PM
Advanced Member Group: Members Posts: 3,430 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Posted this on my build thread a month ago but figured I'd update here. I think the Rockford-Fosgate sub will work in the foot well location. I just have it mounted on a cheezie temporary board for not until I can get that awesome enclosure Mark is working on (IMG:style_emoticons/default/poke.gif) (IMG:http://www.914world.com/bbs2/uploads/post-20845-1586067181_thumb.jpg) With the enclosure, I'll rig a flush mount with a sturdy grill to keep feet from poking through. I might have to sacrifice about 1/2" of foot space to make it completely flush but won't know for sure until I have the box. Even with the cobbled setup, it is pretty stealth. (IMG:http://www.914world.com/bbs2/uploads/post-20845-1586067451_thumb.jpg) Sound-wise, I liked the JL Audio sub better but this is pretty nice after it got broken in a little. It's a bit wimpy running free-air on that board though so I'm really looking forward to having an enclosure so I can button this up. Nice work, and thanks for posting. How much legroom lost? I had a similar setup, but it was covering a Pioneer bass wedge and it lost a couple of inches of leg room...which was too much. |
bbrock |
May 5 2020, 06:18 PM
Nice work, and thanks for posting. How much legroom lost? I had a similar setup, but it was covering a Pioneer bass wedge and it lost a couple of inches of leg room...which was too much. I'm hoping for zero legroom lost but will have to wait for the sub enclosure that replaces the foot well foam to see. Right now the board the sub is mounted on is in the same location as the front of the foam block. As you can see, the sub is surface mounted right now but I think I'll be able to mount it flush for a zero loss installation. As you know, that is an awkward space and there is a small cavity to tuck the magnet into even on a shallow mount sub. I know enough at this point that this install will lose a max of 3/4" leg room but probably less. |
Lo-Fi Version | Time is now: 19th April 2024 - 11:09 AM |
