Kill switch |
Kill switch |
mlindner |
Jan 31 2019, 03:03 PM
Senior Member Group: Members Posts: 1,514 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Getting close to the end of a build....what is the kill switch of choice. will be mounted on the battery side of the engine cover extension grill. Thanks, Mark
Mark Henry |
Jan 31 2019, 03:15 PM
Moroso, metal construction, better than the plastic units.
https://www.summitracing.com/int/parts/mor-74102/overview/ |
infraredcalvin |
Feb 1 2019, 01:05 AM
Distracted Member Group: Members Posts: 1,509 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
I have a plastic one with removable key on the outside, the metal one mentioned above on the inside. The removable key is a little piece of mind during transport or storage.
Btw some clubs like the kill switch to be within reach or close proximity to the driver, make sure it complies. |
campbellcj |
Feb 1 2019, 07:47 AM
I can't Re Member Group: Members Posts: 4,540 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I'm fairly sure mine is the common OMP or maybe Sparco -- definitely be sure it's the right type with the alternator circuit. Vastly more work to remote-install but that definitely is better, having it over by the driver's side a-pillar/cowl. Mine is near the battery tray though. Most astute clubs / tech inspectors will test it so be sure you do, including at above idle revs...
Downunderman |
Feb 1 2019, 03:29 PM
Senior Member Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand |
These are a bit expensive but very good: https://www.cartekmotorsport.com/battery-isolators/
jd74914 |
Feb 3 2019, 09:41 AM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I always liked these, but not sure about typical track legality. We've run them without issues but they aren't very common. Much better built than the typical cheap Sparco, etc.
https://www.westmarine.com/buy/blue-sea-sys...27?recordNum=16 |
mlindner |
Feb 16 2019, 09:59 AM
Freezin 914 |
Feb 16 2019, 02:43 PM
Senior Member Group: Members Posts: 845 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
Looking good!
Jetsetsurfshop |
Feb 16 2019, 05:31 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
I have that one too. I mounted mine next to me behind the shifter and then ran a pull cable to the the same area you put your switch. I just did it on the drivers side incase I had to do a quick exit and forgot to kill the car.
Looks good (IMG:style_emoticons/default/beer.gif) |
gms |
Mar 20 2019, 10:39 AM
Advanced Member Group: Members Posts: 2,694 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
buz914 |
Apr 2 2019, 10:11 AM
Newbie Group: Members Posts: 26 Joined: 30-April 16 From: Florida Member No.: 19,952 Region Association: South East States |
Be sure to insulate those hot lugs. Otherwise you may have a shower of sparks.
mlindner |
Apr 3 2019, 06:33 AM
Thanks buz914, will do. Mark
Lo-Fi Version | Time is now: 27th April 2024 - 11:41 PM |
