1973 Horn Don’t work |
MiniStevieG |
Feb 5 2019, 01:51 PM
Member Group: Members Posts: 179 Joined: 25-January 19 From: Dallas, TX Member No.: 22,827 Region Association: Southwest Region |
Getting my new whip ready for inspection and discovered my horn has issues. The horn was disconnected from the bumper and now I know why. It won’t stop blowing when I hook the wire back up to the actual horn. I removed the horn assembly on the steering wheel and and for obvious reasons it stops because the mechanism is no longer grounded. I tested the ground wire on the steering wheel and can hear the relay clicking when I disconnect the actual horn so all is good with that. Everything makes sense up till now. Problem is, when I connect the ground wire the assembly and attach it to the steering wheel the horn won’t stop honking. I assume it’s staying grounded when I hook it up. Been troubleshooting it for a little while and I’m wondering what the issue might be. Any thoughts?
1adam12 |
Feb 5 2019, 04:52 PM
Member Group: Members Posts: 209 Joined: 25-May 17 From: Chino Hills, CA Member No.: 21,132 Region Association: Southern California |
If you do have the correct horn pad just make sure it isn't installed upside down. This will cause the horn to make contact due to mis-alignment. Also do an inspection of that rubber boot for cracks.
Lo-Fi Version | Time is now: 25th April 2024 - 06:39 AM |
