> 1973 Horn Don’t work
MiniStevieG
post Feb 5 2019, 01:51 PM
Getting my new whip ready for inspection and discovered my horn has issues. The horn was disconnected from the bumper and now I know why. It won’t stop blowing when I hook the wire back up to the actual horn. I removed the horn assembly on the steering wheel and and for obvious reasons it stops because the mechanism is no longer grounded. I tested the ground wire on the steering wheel and can hear the relay clicking when I disconnect the actual horn so all is good with that. Everything makes sense up till now. Problem is, when I connect the ground wire the assembly and attach it to the steering wheel the horn won’t stop honking. I assume it’s staying grounded when I hook it up. Been troubleshooting it for a little while and I’m wondering what the issue might be. Any thoughts?
isdyl
post May 13 2019, 08:18 AM
Region Association: England
Hi - sorry to open up this thread again but I'm having a similar problem. I have all the bits (I think) in the diagram, but I can't work out how they go together. I have a spring button rather than the spade connector but all else looks similar. I can't see where the rubber cuff sits, and also can't see how the two discs can be made to contact if there's a nylon washer between them? Is there an exploded diagram of this arrangement anywhere please? Any help much appreciated! Thanks, Dylan
MiniStevieG   1973 Horn Don’t work   Feb 5 2019, 01:51 PM
mepstein   You have the correct pieces for the horn pad.   Feb 5 2019, 03:18 PM
MiniStevieG   You have the correct pieces for the horn pad. T...   Feb 5 2019, 03:53 PM
mepstein   You have the correct pieces for the horn pad. ...   Feb 5 2019, 04:41 PM
1adam12   If you do have the correct horn pad just make sure...   Feb 5 2019, 04:52 PM
Dave_Darling   First--when you move the wire up the steering colu...   Feb 5 2019, 05:37 PM
MiniStevieG   First--when you move the wire up the steering col...   Feb 6 2019, 03:49 PM
bbrock   First--when you move the wire up the steering co...   Feb 6 2019, 04:52 PM
MiniStevieG   [quote name='MiniStevieG' post='2686814' date='Fe...   Feb 7 2019, 12:21 AM
MiniStevieG   [quote name='MiniStevieG' post='2686814' date='Fe...   Feb 10 2019, 10:39 PM
Rand   Make your brakes louder?   Feb 5 2019, 08:54 PM
MiniStevieG   Make your brakes louder? Haha!! Man Iâ...   Feb 6 2019, 03:22 PM
Dave_Darling   Also plastic washers under the screw heads. Other...   Feb 7 2019, 03:55 PM
no1uno   Sorry, I couldn't resist...   Feb 7 2019, 04:28 PM
76-914   You won't regret changing out that worn rubber...   Feb 12 2019, 10:59 AM
isdyl   Hi - sorry to open up this thread again but I...   May 13 2019, 08:18 AM
Dave_Darling   Check the first picture in this thread. That...   May 13 2019, 05:26 PM
mepstein   Check the first picture in this thread. That...   May 13 2019, 05:33 PM
Larmo63   I've futzed around with the tiny wire you have...   May 13 2019, 06:21 PM
mepstein   I've futzed around with the tiny wire you hav...   May 13 2019, 06:52 PM
isdyl   Many thanks - I'll have another go at it today...   May 14 2019, 12:17 AM
isdyl   Great - all working thanks!   May 14 2019, 03:30 AM
Rand   I'm offering up props here. So many times thre...   May 14 2019, 11:28 AM
- Lo-Fi Version Time is now: 16th April 2024 - 07:35 AM
