74' Marathon Blue with Subaru 3.6 engine, sometimes life sucks |
Chi-town |
Feb 5 2019, 07:51 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Well you know what they say, the best laid plans of mice and men...
1974 1.7 Marathon Blue 132k on the clock $9k On Hold, might be able to keep her The Good No rust in the hell hole, longs, floors, jack points, trunks 911 Front Boge Struts with new Bilstein HD inserts New Ball Joints (Lemforder) New Turbo Tie Rods (Lemforder) New SKF front wheel bearings and seals New front Rotors (Centric) Alfa Brembo Aluminum Calipers (just rebuilt) Lower control arms just powder coated New Powerflex Black front control arm bushings New Fuel Tank New Stainless Fuel Lines 911 Rear Hubs and Stubs (108mm CV size) New Rear Rotors New Rear Pads (Porterfield RS from PMB) PMB adjuster plugs for rear calipers New FAG rear wheel bearings Bilstien rear shocks w/ unknown red springs Maxilite Fuch copies 7" front / 8" rear (tires are old but hold air and roll) New AppBiz Carpet set Tons of new weather stripping Fresh air system just refreshed with all new seals and foam (914 Rubber) New ATE 19mm Mater Cylinder (still in box) Luissi Steering wheel and solid hub 2013 Subaru Outback 3.6L Engine (35k miles, 256hp/243ftlbs) Subarugears 108mm CV adapters for Subaru 5MT Subaru 5MT FWD Conversion kit Front Sway Bar Rear Sway Bar 22mm Hollow Sway-a-way torsion bars Tons of spare parts! The Bad Some of the above parts are not yet installed (car does roll!) Engine and trans are not installed (waiting on a new cradle) Paint / Body has patina Car was converted to electric in the past, has 5 small odd holes cut in trunks Bumpers are there but not perfect (no rear bumper top) No Battery tray (electric conversion victim) Had aftermarket mirrors (extra holes) I'm located in Anaheim, CA I will load more pics tomorrow now that the rain has stopped. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1084.photobucket.com-22446-1549417924.1.jpg) |
JRust |
Feb 5 2019, 09:07 PM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
What was your plan on the motor for ECU? Stock & do you have the complete wiring harness to get it? Will be fairly important to whoever takes the project on
Chi-town |
Feb 5 2019, 10:01 PM
The plan was to run a Link Thunder or Fury ecu as they have a map that allows you to run all the factory sensors. I have not purchased it yet but I do have the connector to wire it directly to the OEM engine harness and all the wiring manuals in PDF to go with it.
Tdskip |
Feb 6 2019, 08:00 AM
Advanced Member Group: Members Posts: 3,681 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Oh crud, sorry man.
mobymutt |
Feb 6 2019, 12:31 PM
Senior Member Group: Members Posts: 548 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
mr2by4 |
Feb 17 2019, 09:14 AM
Member Group: Members Posts: 182 Joined: 9-December 07 From: Fort Worth Member No.: 8,439 Region Association: Southwest Region |
More pictures yet?
Feb 17 2019, 09:15 AM
914-6 GT in waiting Group: Members Posts: 19,234 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
A lot of project for the money. GLWTS.
Chi-town |
Feb 18 2019, 03:56 PM
On Hold for the moment
76-914 |
Mar 1 2019, 09:23 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,488 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Crap. I just saw this. I'm hoping it all works out for you Dylan. We need Suby minds. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 23rd April 2024 - 04:33 AM |
