Gasoline - 90 Octane, Ethanol Free (89), or additives, How to reduce valve knock |
dcecc1968 |
Feb 6 2019, 07:46 AM
Member Group: Members Posts: 251 Joined: 31-December 12 From: Concord, NC Member No.: 15,313 Region Association: South East States |
We are having some Spring weather this week in Charlotte, NC (and no rain!) so I've been driving the 914 and noticed that after about 20 minutes of driving, the valves intermittently knock from "normal" to very loud for no apparent rhyme or reason.
Outside of the obvious that it may be time for a valve adjustment, I wondered what Gasoline grade folks are using. What Petro are you using in your 914? |
Dave_Darling |
Feb 6 2019, 01:13 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
If it really is valve noise, the probable causes range from valves sticking in the guides, to wiped lifters and/or cam lobes. Even dropping valve seats...
Is the motor stock or modified? If it is pinging, there are other things to check. How's your ignition timing? Air/fuel mixture? --DD |
Lo-Fi Version | Time is now: 26th April 2024 - 12:44 AM |
