Garage Lighting, Garage Demo - Looking for direction |
ctc911ctc |
Feb 6 2019, 10:27 AM
Senior Member Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
All Teeners,
I did a search within this list not sure this was covered previously. I am going to demo my garage interior. install lighting, electric, heated floor, the whole deal. My question is what is the direction to go as to the in ceiling lighting? Fluorescent is the path I was heading, though LED is getting better, Any experience with _products_ that are working well for the people in this forum? Thanks! CTC911CTC |
KELTY360 |
Feb 6 2019, 12:26 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
LEDs are no doubt superior. Think perimeter for placement. Running lights down the center of a bay is a waste of lumens. If you have appropriate space, you can also install a light at ground level to aid illumination under the car. Another great convenience is a motion sensor light with the sensor aimed at the garage entry. That way you’ll always have light when you enter and leave the room and if your hands are full you won’t have to flip the switch.
Pay close attention to outlets also. Can’t have too many. Consider putting some at ground level. Also, many electricians will run multiple circuits with outlets alternated so you don’t overload when using multiple, large draw tools in the same area. |
tmc914 |
Feb 6 2019, 06:15 PM
Member Group: Members Posts: 116 Joined: 24-September 17 From: Lowell, MA Member No.: 21,452 Region Association: North East States |
LEDs are no doubt superior. Think perimeter for placement. Running lights down the center of a bay is a waste of lumens. If you have appropriate space, you can also install a light at ground level to aid illumination under the car. Another great convenience is a motion sensor light with the sensor aimed at the garage entry. That way you’ll always have light when you enter and leave the room and if your hands are full you won’t have to flip the switch. Pay close attention to outlets also. Can’t have too many. Consider putting some at ground level. Also, many electricians will run multiple circuits with outlets alternated so you don’t overload when using multiple, large draw tools in the same area. Please be careful mounting anything electrical below 18" in a commercial garage. National Electrical codes requires them to be explosion proof at such a low height. Residential homeowners get a break from that but I would not mount outlets or lights low in my garage at home. It is one thing to use a portable light down low or even a vacuum cleaner without much concern but permanently mounted electrical is just asking for trouble. Also don't forget the outlets need to be GFCI protected at any height in a garage. |
Lo-Fi Version | Time is now: 26th May 2024 - 06:18 AM |
