HELP- 914-6 Headlight question?, Right front hi beam not working |
R8CERX |
Feb 6 2019, 01:30 PM
2014 New year resolution: To get along with Woody... Group: Members Posts: 606 Joined: 5-June 13 From: California Member No.: 15,972 Region Association: Southern California |
Folks
My right side 914-6 headlight high beam is not working (original 6 circuitry) Low beam works on both sides High bean only works on left side; right side is off Fog lights work (IMG:style_emoticons/default/idea.gif) I bought new lights (H4s) and replaced it thinking it was a bad high beam New light did not work on high, only low beam I replaced a third light to confirm and same-- (IMG:style_emoticons/default/WTF.gif) Fuse box under dash all my fuses are good--but is there one fuse that controls the right and left high beam separately? it would not make sense that there is a fuse only for one side of the light and only for high beam.... the rear engine relay, does it have anything to do with the lights? I am trying to see where or what I need to check, specially if low bean works there are three wires in the back of the light--how do I check voltage to see if the connector is bad? Me not a good mechanic.... simple questions for many of you, but for yours truly.... not that simple...I am trying to be like all you cool katz that can do all of the fixes on your own!! (IMG:style_emoticons/default/blink.gif) any help/suggestions are appreciated.. pictures of diagrams will help if you have any! Gracias! (IMG:style_emoticons/default/headbang.gif) |
Dario |
Feb 10 2019, 05:42 PM
Newbie Group: Members Posts: 10 Joined: 21-June 15 From: Florida Member No.: 18,875 Region Association: None |
[quote name='R8CERX' date='Feb 6 2019, 11:30 AM' post='2686786']
Folks My right side 914-6 headlight high beam is not working (original 6 circuitry) Low beam works on both sides High bean only works on left side; right side is off Fog lights work (IMG:style_emoticons/default/idea.gif) I bought new lights (H4s) and replaced it thinking it was a bad high beam New light did not work on high, only low beam I replaced a third light to confirm and same-- (IMG:style_emoticons/default/WTF.gif) Fuse box under dash all my fuses are good--but is there one fuse that controls the right and left high beam separately? it would not make sense that there is a fuse only for one side of the light and only for high beam.... the rear engine relay, does it have anything to do with the lights? I am trying to see where or what I need to check, specially if low bean works there are three wires in the back of the light--how do I check voltage to see if the connector is bad? Me not a good mechanic.... simple questions for many of you, but for yours truly.... not that simple...I am trying to be like all you cool katz that can do all of the fixes on your own!! (IMG:style_emoticons/default/blink.gif) any help/suggestions are appreciated.. pictures of diagrams will help if you have any! Gracias! You have 4 fuses 1 & 2 are left and right high beams, 3 & 4 and left & right headlamps. Hope that helps |
Lo-Fi Version | Time is now: 20th April 2024 - 05:17 AM |
