Engine bay cable "snorkel", installation advise |
draganc |
Feb 7 2019, 11:09 AM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
hi folks!
any advise how to install the rubber engine "snorkel", covering the wire harness exiting the tunnel? The original rubber grommet is all cracked up and I was think it would be a good idea to replace, while the engine is out. I have been staring at it for an hour, but can only come up with disassembling all the connectors and even then it looks like a tight fit. Any "alternative repair" advises are also very much appreciated. Cheers, dc |
Specracer |
Aug 20 2019, 09:27 AM
Member Group: Members Posts: 100 Joined: 27-March 17 From: SE Mass Member No.: 20,970 Region Association: None |
I went a different route, the snorkel was cracked, but the ends going to the shelf and bulkhead, were OK. I just could not stomach changing the snorkel, even when the harness was out of the car. I used a waterproof tape that I found on Amazon. Its a stretchy self clinging rubber membrane. Secured with a wire tie at the end to guarantee it wouldn't unravel.
draganc |
Aug 31 2019, 10:14 PM
I went a different route, the snorkel was cracked, but the ends going to the shelf and bulkhead, were OK. I just could not stomach changing the snorkel, even when the harness was out of the car. I used a waterproof tape that I found on Amazon. Its a stretchy self clinging rubber membrane. Secured with a wire tie at the end to guarantee it wouldn't unravel. Can you share a link or product details? |
Lo-Fi Version | Time is now: 17th May 2024 - 06:21 AM |
